I updated 2 days ago and it went offline once a day. The hub keeps blinking after web offline and I have to unplug → plug again
This might be caused by network fluctuations. To ensure network stability, it is recommended to use a wired connection.
Hey there and welcome to the forum.to me it happened before too after an channel change on my 5Ghz band.how i fix it was by unplug the M3 for the power for about 1/2 min and plug it back this for me worked and never had an issue since then
Were both outages on Wi-Fi, or was the M3 already using Ethernet? If it happens again, does the router still list the hub as connected, and do local Zigbee automations continue running? Those observations would help distinguish a lost network connection from a wider hub problem; the timing after the update alone does not establish the cause.
It’s using wifi but wifi and internet are not down. All the automation stopped working, that is how I noticed. The first time the router didn’t detected disconnection, the later I did. I have never have this issue before
It haven’t happened today yet so still monitoring
