Aqara / Ikea KAJPLATS Matter Integration?
Has anyone tried integrating the new IKEA TRÅDFRI Matter bulbs directly to an Aqara Matter hub yet, such as an M3?
Looking to purchase some of the exposed filaments bulbs.
Thanks
I only bought the new temperature sensor called Timmerflotte yesterday and initially paired it with the IKEA Diriger Hub using Matter over Thread.
My IKEA Diriger Hub is exported to the Aqara M3 Hub via Matter so that I have all my IKEA products in the Aqara ecosystem.
However, the sensor wasn’t exported in this workflow, which makes sense.
Only after activating pairing mode in the IKEA app and generating a new Matter code I was able to successfully pair the sensor with Aqara using this new code.
Many people think that the code on the product packaging can be used anytime, anywhere. This isn’t the case, because once it’s been used, you have to generate a pairing code from the first system to integrate the product into other ecosystems.
Regarding your question: It should most likely work if you’re using the new KAJPLATS bulbs. These have direct Matter over Thread. The older versions called Tradfri will not work directly in Aqara because Aqara does not directly accept third-party Zigbee devices.
Normally should 3rd party Matter bulbs be able to integrated directly to Aqara M3 / M100
Thanks, you’re correct! I’ve update the post title to include KAJPLATS
Long Story short: should work :wink:
I have Kajplats bulbs and they pair straight away. No luck with the Bilresa remotes though
I have tried the Bilresa too! And yes, binding often runs out there too ! But at the end I got all integrated by my M3
I recommend resetting all new IKEA products to factory settings before pairing them.
This has always worked for most people.
Looking on the forum, seems a known issues with Bilresa remotes and the android app.
