Has anyone else run into this? My Aqara leak sensors periodically send a disconnection notification at random times, then reconnect by themselves a little later.
My first thought was range, but that doesn’t seem to be it. One of the affected sensors sits right next to the hub. My guess is it happens when the sensor has been asleep for a while and the app interprets that as a dropout.
Functionality doesn’t seem to be affected. Right after getting a reconnection notice, I dropped one of the sensors in water and got the leak alert immediately.
This only happens in the Aqara app. I’m not seeing any false disconnects in HomeKit or Home Assistant, which use the same sensors.
Is there a setting to fix this, or is it just a known quirk of the Aqara app? Any suggestions appreciated.
I’ve had that happen on occasion. Originally I would pull the battery for 30 seconds in the leak sensor and push the button on top and reconnect it and it would solve the issue.
Then after it happened 1 or 2 more times over a few months it occurred to me that it was acting as a (canary in the coal mine) and a warning my Hub was disconnecting from WiFi.
Turns out it was true the M1S Hub all my water leak sensors are connected to was dropping off the Network.
Just something to look at and pay attention to if it keeps happening.
The timing of the test is the useful missing piece here. An alert after reconnection shows the sensor worked then, but cannot tell us whether the earlier warning was app-only or a real interruption. I would not take an unchanged dry state in Home Assistant as an independent connectivity check either.
Before re-pairing anything, I would save the sensor and hub models, hub firmware, HA integration, and the exact offline and online timestamps for one incident, then check whether a fresh sensor event reached HA during that interval. HA’s state documentation distinguishes state changes from reports, so last_changed is not a “last heard from the sensor” check. Are the affected sensors the same model, and do their warnings occur together or at separate times?
