This text is copied from an Alexa forum, just for clarity.
Advice and help please. I have a set of “Dumb” lights running up the side of my stairs. These are plugged into an Alexa enabled plug, so if i say “Alexa, Stairs on” the lights come on. And the same for turning them off. All good so far.
However I wish to take this further and have Motion/presence sensor with a combined light sensor (they exist in lots of forms).
I bought an Aqara P2 sensor and M100 hub. Paired them via Matter, they are recognised in the Alexa app and I’ve created a routine to basically say “when you detect movement turn on the plug, wait 15 seconds then turn off”
This does not function at all.
I have since realised that Alexa does not do light sensor side of things dispite Aqara customer services saying it would work.
I can’t seem to create the routine in the Aqara app, and don’t think it would work anyway because the sensor has no way to turn on the lights.
What am I missing please? What do i need to do to make the lights come on when it detects motion but only at a certain level of brightness. Im happy to set up an automation in the Aqara app but for some reason I cant.
The catch with Matter devices is that you always need a Matter controller for the specific ecosystem where you want your automations to run. For example, you need the M100 for Aqara automations, and a compatible device (like an Amazon Echo 4th Gen or Echo Hub) for Alexa automations.
This means you currently have a few options:
a) You use a Matter controller (like a compatible Echo device) and connect the P2 sensor directly to it via Matter.
b) If your Alexa smart plug is Matter-compatible, you can simply integrate it into your Aqara system.
c) Replace the P2 Sensor (Matter over Thread) with a P1 Sensor (Zigbee). Then, the P1 can be shared with Alexa via the third-party ecosystem service (Aqara Home app → Profile → Connect to Ecosystems → Amazon Alexa).
d) Alternatively, you can also replace the smart plug with one from Aqara if the one you have isn’t compatible with Matter.
Important note: While Alexa supports motion sensors as triggers for routines, it currently does not provide a way to set a brightness value (lux) as an additional “AND” condition (e.g., “If motion detected AND brightness < X”). This means that options a) and c) are effectively ruled out.
Unfortunately Matter-only devices are not bridged directly to another ecosystem by the hub.
They are upgrade to Zigbee - Matter devices are meant to be controlled by each ecosystem directly (a Matter device can be paired with multiple hubs). It also allows to connect third party devices to one hub - which is why people connect Ikea lightbulbs to Aqara hubs, or Aqara sensors to other third party ecosystems (without Aqara hubs).
Zigbee can only be paired with one ecosystem/network. And because of that limitation Zigbee devices are bridged by the hub to the other ecosystems.
Unfortunately, in your case it looks like your Alexa ecosystem just doesn’t support Matter. If all your devices were Matter-enabled (no matter the brand), then you would just need one Matter hub and you could pair all those devices to the hub and create automations.
But if you want to use Aqara sensors, then you need to apply the solution suggested by @JohnD. You need older P1 sensors (or newer FP300), which support Zigbee. Then the hub will bridge the Zigbee devices automatically (like you wanted) and your Alexa automations will work.
