Aqara Permanent Outdoor Lights review
Installation went well!
The person helping me said they were much better than Govee lights because the lights were further apart and because Aqara lights came with extensions to put between the light strands. Those extensions helped a lot (not usually included with Govee lights)! I wish there was a way to put them in between every light. Or maybe some strands of lights were a different lengths, so we could use a smaller strand if we had extra lights in an section. We started at the highest point of the eaves and moved down, which made the spacing on both sides match perfectly.
You’re able to turn individual lights off for all automations! So if a light is in a strange spot, it can be individually turned off.
It ended up looking much better than I expected.
Operating in the App is a little difficult, I usually end up using AI to create most of my scenes.
I wish there was a way to call the scenes from Home Assistant (Connected through Matter)! The Music Sync options are available through Matter, but none of the scenes I save. I also have Govee lights outside, so to get everything looking similar I have to open both apps and select a scene (If HA could call scenes, I could control Govee and Aqara with one action in HA).
I wish there was a way to send RGB codes from Home Assistant. Or type in the numbers into the App. It’s really hard to get the exact color you want on a phone screen.
I also with there was a way to program a light show with them. I’m still learning, so maybe something out there could help synch them with Govee devices and/or my Zigbee Christmas outlets. It would be great if I could run a program that is timed exactly to music (instead of all devices listening for music).
I’m really enjoying the lights, my neighbors ar jealous and I can’t wait to see what else I can do!
Good tip to start at the highest point of the eaves. Being able to turn off a single light that ends up in a strange spot is a nice feature too.
Hello @jacksonvillejohn
Thank you for sharing your outdoor lighting setup with us. It looks amazing.
:omzdu6fxikcn5wgqqcyj9q_62:
Great variety of colors! Which garden lights do you use?
