In my experience, the sensor works very well with plexiglass shower enclosures, meaning it detects people even through the plexiglass.
However, it doesn’t like pure glass or mirrors. Placing an FP2 directly opposite a mirror or a window can trigger error messages. At least, that’s my experience.
In this case, the sensor wasn’t placed directly behind a pane of glass, but in a corner of the room with the window directly opposite. Angling the sensor significantly reduced the error messages.
Yes, mmWave presence sensors like the Aqara FP2 can technically detect through glass, since radar waves are not blocked by transparent materials in the same way as infrared.
BUT — it depends heavily on the type of glass:
Standard window glass: Usually works fine. Radar waves pass through with only minimal loss, so presence detection generally still works.
Double- or triple-glazed windows: These can reduce signal strength, especially if they have metallic coatings (like low-emissivity/low-E layers used for insulation or mirrors). That can block or reflect the radar signal — and then detection may become unreliable or even fail entirely.
Also, radar sensors sometimes pick up reflections, which could cause unexpected results or false positives.
So while the answer is technically “yes”, the real-world performance will vary.
Best advice: Test it in your environment before relying on it for critical automations.
Always remember: “If your car is smarter than your home… you’re driving into the future while living in the past”
Spot on and the triple layer is for sure a no go as then distance between the 3 layers varies to also cancel out sound waves so all for of waves would be heavily reduced.
