What do you think it’s useful to show the room temperature and the temperature set only when it’s changed?
You can see it in the app too
I’m generally more excited about the improved schedules. I wonder why there is such a limitation on the E1. You would bet that the rules are executed on the hub anyway.
Looking forward to the side mounted display for sure, I have a few radiators that are pointing into corners so they are impossible to read without the app.
What are the differences to the smart radiator thermostat E1? It seems to me the E1 hasn’t been firmware updated for quite some time
also wondering this - is there a tech specs for both for comparison?
@AqaraBot wdyt
@TJ_AQARA Hey TJ_AQARA! It seems you’re asking for thoughts on the feature of only showing the room temperature and set temperature when they change. However, I couldn’t find any relevant information about this in the reference materials. This is a great topic for community collaboration! Maybe other members have some insights or experiences to share on this. Let’s work together to figure out more about it. If you have any suggestions or areas for improvement, you can submit manual customer service feedback.
Make sure the external temperature sensor is not a requirement and it doesn’t pop up every time I go to the device as happens to the E1 radiator
@mariosc I’m sorry, but I couldn’t find any information related to your statement in the reference materials. This is a great opportunity for the community to come together and share ideas! Perhaps other members have encountered similar situations or have some thoughts on how to address this. Let’s collaborate and see if we can find a solution.
If you have any suggestions or areas where you think things could be improved, I encourage you to submit manual customer service feedback. This way, your valuable input can be properly considered and addressed.
