Aqara s1 Siri integration
Hi, I live in Sweden and in the latest firmware version of the s1 hub you added Siri to integration with apple home, but I cannot find the Siri activation button in the home app for the MagicPad-S1-Plus-E322 accessory.
What can I dot to get this working ?
Devices You’ll Need:
  • MagicPad/Panel Hub S1 Plus
  • HomePod (any verison)
Step 1: Get Everything Up-to-Date
First things first: Please make sure both devices are running the latest software to avoid any glitches:
  • Upgrade your MagicPad/Panel Hub S1 Plus to version number 4.5.1_0051.0017.
  • Upgrade your HomePod to the newest version available online.
Step 2: Add your S1 Plus to Apple Home
Next, you need to get the S1 Plus added to your Apple Home.
  • Please add the [S1 Plus] to your Apple [Home App].
  • Crucial Note: Your HomePod and the S1 Plus must be connected to the exact same Wi-Fi network (the same local network) for this to work.
Step 3: Enable Siri Settings
Finally, jump into your Home App to configure the voice control.
  • Open the Apple [Home App] (“Home” icon).
  • Find your [S1 Plus].
  • Go into the device’s settings and turn on the relevant [Siri] on settings.
So the S1 doesn’t have a microphone? I have an Apple TV.
The S1 plus has a microphone- you can use it similar like a HomePod
Yes thats what I have and I have the latest version of everything, but it’s not working I have the s1 plus.
My version number is 4.5.1_0058.0017 that’s the latest I can get.
Everything is connected to the same WiFi.
Can you help me solve this?
Hello, I updated the firmware and enabled Siri, but when I say “Hey Siri,” absolutely nothing happens. What should I Do?
Maybe restart the devices? for me it worked right away, i said hey siri and homepod was not responding but then i saw because i was closer to the S1 it woke up to the dashboard and siri sign on the bottom was working. did not do anything but update to the 4.5.1 firmware
Did you allowed the access in Apple home?
Now it recognizes it as a HomePod but it still doesn’t work.
The image is from when I activate/deactivate the Siri voice recognition in my profile.
I still cannot see an activation switch/button on the s1 settings in home.
Siri language is set to English everywhere.
Are you sure I don’t need a HomePod to get this working?
Am looking at the same screens right now. Did you ever get it sorted?
