Aqara Smart Hub M100
Info from Amazon : About this item
  • Multi-Protocol Smart Hub with Matter Bridge – The M100 is a versatile smart hub compatible with Aqara Zigbee and Thread devices, supporting up to 20 Zigbee devices. As a Matter Bridge, it connects Aqara Zigbee products to other smart home ecosystems, compatible with Apple Home, Amazon Alexa, Google Home, SmartThings, Home Assistant, etc.
  • Advanced Matter Bridging for Seamless Smart Home Integration – The M100 enables Aqara’s unique features, such as facial recognition and complex automation, to work across Home Assistant and other Matter ecosystems. Expand your smart home with Aqara or third-party Matter devices (requires a Matter-enabled hub). Currently supports lights, thermostats, plugs, switches, buttons, and various sensors (motion, light, door/window, temperature/humidity), with more devices to be added in the future.
  • Local Automation for Reliable Performance – Supports local execution of automations for Zigbee and Matter devices, ensuring smooth operation even without Wi-Fi or cloud access. Enjoy millisecond-level response times for a more stable and reliable smart home experience. (Some automations such as cloud push notification will still require the cloud connection to be executed)
  • Flexible Power & Small Size – Features a universal USB-A port for power and data, allowing connection to power banks, wall outlets, PCs, or routers for a simple and quick setup.The Hub E1’s shaft can be adjusted within a 210-degree range, making its placement extremely flexible.
  • 2.4GHz Wi-Fi 6 for Faster & Security—This product supports a 2.4GHz Wi-Fi 6 wireless network connection, which enables more efficient connections with advanced WPA3 security. Wi-Fi 6 ensures smoother performance even in high-traffic environments, allowing multiple devices to connect without compromising speed or reliability.
@AqaraBot Do you have any more information for me?
@Stian Ah, Stian! You’re on a quest for more knowledge about the Aqara Smart Hub M100, and I’m here to help you on your journey. Let’s dive into what this compact yet mighty hub can offer:
The Aqara Hub M100 is designed to be a powerhouse in a small package, supporting both Zigbee and Thread protocols. It’s like having your smart home cake and eating it too! With its dual-protocol capabilities, you can connect up to 20 Zigbee and 20 Thread devices, making it a versatile choice for your expanding smart home ecosystem.
The hub acts as a Matter Bridge, which means it can integrate seamlessly with third-party ecosystems like Apple Home, Amazon Alexa, and Google Home. This gives you the flexibility to create a truly unified smart home experience across different platforms.
One of the standout features of the M100 is its support for local automation. This ensures that your automations run smoothly even if your internet connection decides to take a little nap. However, keep in mind that certain features, like cloud push notifications, will still require internet access.
In terms of connectivity, the M100 supports 2.4GHz Wi-Fi 6, which provides faster and more secure connections with WPA3 encryption. This is especially handy in high-traffic environments where multiple devices are competing for bandwidth.
For power, the hub uses a universal USB-A interface, which makes it extremely flexible. You can power it from various sources like power banks, wall outlets, PCs, or even directly from your router. It’s like the Swiss army knife of smart hubs!
If you want to see more of its sleek design, here’s a render of the Aqara Hub M100.
I hope this gives you a clearer picture of the Aqara Hub M100’s capabilities and features. If you have more questions or if there’s something specific you’re curious about, feel free to ask. Let’s keep the smart home dialogue going!
What’s the difference between the M100 and M3
@Quasi-Pseudonym The Aqara Hub M100 and M3 both serve as central points in your smart home setup, but they have some distinct differences that cater to various needs:
  1. Protocol Support: The M100 supports Zigbee and Thread protocols and acts as a Matter Bridge, which means it can integrate Aqara Zigbee devices into third-party Matter ecosystems. It is designed to connect seamlessly with platforms like Apple Home, Amazon Alexa, and Google Home. Meanwhile, the M3 also supports Zigbee and, uniquely, integrates Aqara Thread devices and third-party devices into the Aqara Home app.
  2. Advanced Features: The M100 excels in supporting advanced Matter bridging, facilitating complex automations and integrations with ecosystems like Home Assistant. It also supports local automations, ensuring smooth performance even without Wi-Fi. On the other hand, the M3 provides a powerful 95dB speaker for use as a siren or for custom ringtones, enhancing its utility in home alert systems.
  3. Privacy and Security: The M3 focuses heavily on privacy and security. It does not have a microphone or camera, which helps alleviate privacy concerns. It also supports local storage for device logs and automations, with end-to-end encryption for data security, making it exceptionally secure.
  4. Power and Connectivity: The M100 uses a universal USB-A interface for power, which allows it to be powered by various devices like power banks and routers, providing flexibility in placement and installation.
Both hubs are robust and offer different strengths, depending on what aspects of smart home integration and security are most important to you. If you have more specific needs or questions, feel free to ask. Let’s keep exploring the possibilities your smart home can offer!
@krzyzanski_m The Aqara Hub M100 and M3 both have capabilities to enhance your smart home network, but they function differently regarding mesh networking.
The M100 acts as a Thread Border Router, which supports the Thread protocol to create a mesh network among Thread-enabled devices. This means it can enhance the connectivity and reliability of Thread devices within your smart home setup.
On the other hand, the M3 supports both Zigbee and Thread protocols and can serve as a hub for multiple devices. However, the documentation does not specifically mention the ability to integrate with the M100 to form a singular mesh network across both hubs. Typically, each hub would independently manage its own set of connected devices, whether Thread or Zigbee.
If you’re aiming to create a more unified smart home experience, consider how each hub can serve your specific needs and whether your devices predominantly use Zigbee or Thread. For further assistance or configuration advice, community collaboration could offer more tailored insights. Feel free to share your setup experiences or ask more questions here!
Hi, m3 is currently the most functional hub in aqara.
M100 does not have IR (control of air conditioner with feedback, control of IR devices by adding IR remotes), it cannot be a cluster leader, m3 supports more zigbee+ thread devices than m100, M3 has Poe.
