Aqara Smart Hub M3 + FP2 Presence Sensor: Matter Bridge Question
Does the Aqara Smart Hub M3 support Matter Bridge functionality to share the Aqara Presence Sensor FP2 with other Matter hubs? I’m hoping to use Matter Bridge to make the FP2’s room presence detection available across multiple Matter hubs in my setup.
@zubair Yes, the Aqara Smart Hub M3 supports Matter Bridge functionality. This means it can bridge Zigbee devices, such as the Aqara Presence Sensor FP2, to platforms that support Matter. The Hub M3 acts as a Matter controller, which allows you to integrate the FP2’s room presence detection with other Matter hubs in your setup. This integration can enhance your smart home experience by making use of the FP2’s advanced features like multi-zone individual positioning and presence detection across different platforms. Feel free to share your setup experiences or ask further questions if you need more assistance!
@zubair The Aqara Smart Hub M3 does support Matter Bridge functionality, which can connect Zigbee and IR devices to platforms supporting Matter . While the reference information doesn’t explicitly specify the Aqara Presence Sensor FP2’s protocol, if the FP2 is a Zigbee device (common for Aqara sensors), the Hub M3’s Matter Bridge should help share its room presence detection with other Matter hubs.
This setup could potentially make the FP2’s data available across your multiple Matter hubs, though actual performance may depend on specific configurations. Have you tried setting up the Matter Bridge with other devices before? Feel free to share your experience or further questions—community insights can be really helpful!
If you need more detailed steps or encounter issues, you can also check the Aqara Home app for guidance or contact customer service for personalized support.
@zubair The Aqara Smart Hub M3 does support Matter Bridge functionality, which can connect Zigbee and IR devices to platforms supporting Matter . Since the Presence Sensor FP2 is a Zigbee device (as it requires a hub for connectivity, and Aqara’s typical sensor connectivity is via Zigbee), the Hub M3 can bridge it to other Matter hubs, making its room presence detection available across your Matter setup.
This should help you integrate the FP2 into your multi-hub Matter ecosystem. Have you tried setting up the Matter Bridge with other devices before? Feel free to share your experience or any follow-up questions—community insights can be really helpful!
If you encounter specific issues during setup, you can also reach out to customer service for further assistance.
@zubair Yes, the Aqara Smart Hub M3 supports Matter Bridge functionality, which connects Zigbee and IR devices to platforms supporting Matter . This means it can share devices like the Aqara Presence Sensor FP2 (assuming it uses Zigbee) with other Matter hubs, potentially making the FP2’s room presence detection available across your multiple Matter hubs setup.
Hope this clarifies things! Feel free to share how it works out once you test it—would love to hear your experience.
