Aqara Smoke and Carbon Monoxide Sensor
Since Google is no longer making their Protect smoke and CO detector, I am looking for a replacement. I see an Aqara smoke detector but not seeing any CO sensors. Could someone please confirm that there are no smoke/CO sensors for the US region?
I’m also open to suggestions for replacements if you all have had good luch with any.
This is the information so far about the next smoke alarm.
Aqara Smoke Alarm P100 – Key Features
The Aqara Smoke Alarm P100 is a smart photoelectric smoke detector designed to provide reliable fire protection for homes and workplaces.
Key features:
  • Dual protocol: Zigbee and Thread.
  • Adjustable smoke detection threshold to help reduce false alarms.
  • Audible and visual alarms when smoke reaches the configured threshold.
  • Real-time smartphone notifications through a compatible gateway.
  • Interconnected alarms for coordinated warning.
  • Self-diagnostics for normal operation and smoke chamber contamination.
  • Low-battery and contamination notifications.
  • Sound and light testing , with a physical test/mute button.
  • Alarm muting locally, through the app or via infrared.
  • Reminders when the alarm has not been tested for a long period.
  • Insect-resistant mesh to help protect the smoke chamber.
  • Local black-box storage and smoke concentration trend recording.
The P100 combines traditional smoke detection with smart monitoring, maintenance reminders and connected alarm functionality.
Sources:
The only semi-affordable thing I’ve seen is by MOES. Wish there was a good combo one.
Have you heard if there will be a hardwired version? Many places require that now.
There are two that I know of, both Matter certified the Owl Wired or the more affordable Sensereo MSC-1 which also uses Thread.
I haven’t found any information about a hardwired version of the P100.
In Norway, new homes require at least one mains-powered, interconnected smoke alarm with battery backup on each floor. Hopefully, Aqara will introduce this in a future model.
I have this one from Elko/Schneider, which requires an Elko Hub. I expect it will eventually support Matter/Thread.
Well there are 2 models but from other brands witch are matter and works in America and Canada.
1.Heiman Smart Smoke detector model S1-M this is batterie powered and is matter over thread and only detects smoke
2.Owl home thus from what i read is the replacement for the Google Nest Protect witch is wired and is matter over WiFi but this have more detections then the heiman.
3.Meross smoke detector kit (MA151H) but this comes with Meross hub to expose it to HomeKit kit or any other 3th party platform.
Sow if you do not want to wait till Aqara will release the new smoke detector you can check those 3.
Thanks for the info
Thank you everyone for all your info… looking forward to when Aqara releases their smoke detector to replace my Nest Protects. :canada::crossed_fingers::+1:
