Hi all,
I’m hoping for some advice on a stubborn Zigbee issue with two Aqara T1 LED strips I bought at the same time.
Setup
- Base system: Home Assistant Yellow
- Integration: ZHA
- Coordinator: Built-in Yellow Zigbee radio (on USB extension)
- Zigbee channel: 20 — note: changing the channel fixed it for my second strip
- Other devices: Several mains-powered Zigbee routers present (plugs/lights/switches)
- Firmware: Latest firmware available for Home Assistant (unable to check T1s)
The issue
One of the two Aqara T1 strips regularly drops off the Zigbee network. It becomes unavailable and only a manual power cycle (unplug/replug) makes it rejoin. This keeps happening even after a reset/re-pair. The strip is physically right next to the Zigbee coordinator, and I do have other routers in the mesh.
What’s strange: Changing the Zigbee channel solved the problem for the other T1 strip, but this one still keeps dropping.
What I’ve tried
- Factory reset + re-pair (multiple times)
- Leaving the device powered and letting it “find its way back” (it doesn’t)
- Moving it between different outlets
- Verified other Zigbee devices are stable
- Channel change (helped the other T1, not this one)
Observations
- The failing strip is very close to the coordinator (could near-field RF or desense be an issue?).
- When it’s online, it works fine; after some time (hours/days), it silently falls off and won’t rejoin by itself.
- Power-cycling the strip brings it back immediately.
Questions for the community
- Known quirk with Aqara T1 strips on ZHA?
- Too close to coordinator? Has anyone seen drops when a device is too near the coordinator? Would moving it 1–2 meters away help?
- Firmware: As I’m not having an Aqara hub I don’t know if there is a new firmware — anyone seen improved stability after an update?
- OTA support: Does anyone know if OTA updates for Aqara products will be officially supported in ZHA?
- Channel choice: I’m on channel 20 (EU). Any recommendations for channels that play nicest with Aqara devices?
If anyone has this exact strip working reliably, I’d love to know your coordinator model/firmware, Zigbee channel, and whether it’s stable for you on ZHA with the latest firmware. And if you’ve seen one unit be flaky while an identical twin on the same network is rock solid, what ultimately fixed it?
Thanks in advance!
