Aqara T1M Color Control Solution
I recently got the Aqara T1M smart lights and paired them with my Home Center 3 via Zigbee. The setup was smooth, and I was excited to start customizing them. However, I quickly noticed that while I could adjust the brightness and color saturation, changing the actual color wasn’t working as expected. This was a bit frustrating because I was really looking forward to experimenting with different hues to match my room’s decor.After some research and trial and error, I discovered that the Aqara T1M supports color temperature adjustments but doesn’t natively allow for full-color customization. This realization led me to explore alternative solutions. I found that using a quick app on the Home Center 3 platform was the key to unlocking the color picker functionality I was missing. By creating a simple automation rule, I was able to link the color changes to the touch controls on my smartphone, effectively giving me the ability to select any color I wanted.One of the challenges I faced was combining the states of the main light and the ring light. I wanted both to behave consistently when I pressed the button in my room. After some experimentation, I figured out that I could use the Home Center 3’s built-in logic to ensure that pressing the button would turn both lights on or off simultaneously. This setup not only simplified my routine but also maintained the saved brightness and color settings when switching the lights on or off.Here’s a quick breakdown of how I set it up:- Main Light (QA-MAIN): Configured to turn on when the button is pressed if it’s currently off.- Ring Light (QA-RING): Set to turn off if the main light is already on, ensuring a seamless transition.- Button Automation: Programmed to toggle both lights together, maintaining the saved settings for a consistent experience.This setup has made my lighting system much more user-friendly and visually appealing. The ability to customize colors has truly enhanced my smart home experience, and I’m glad I took the time to figure out the solution. If anyone else is struggling with similar issues, I’d be happy to share more details or help troubleshoot!
