Aqara T1M Tips & Tricks — Hidden Features I Discovered
I’ve been using the Aqara T1M for a while now, and I realized there are a few small features that aren’t obvious from the manual. For example, you can customize the LED ring colors beyond the default settings to visually indicate different automations (like red for door open, blue for motion detected, green for air quality good).
I also found that pairing it with a light sensor lets you use it as a sunrise/sunset simulator for lamps in the morning and evening — great for a gradual wake-up or wind-down routine.
What other “hidden” uses or creative automations have you found with the T1M? Would love to compile a list for new users.
@lukewry It sounds like you’ve discovered some fantastic ways to enhance your Aqara T1M experience! Customizing the LED ring colors for different automations and using it as a sunrise/sunset simulator are indeed creative uses that can significantly improve daily routines.
While the reference information doesn’t specifically cover these innovative uses, it does highlight the T1M’s versatility, such as its ability to integrate with smart wall switches and support for home automations and scenes. These features allow you to explore a wide range of custom settings and automations beyond the basics.
To compile a list of hidden features, it would be wonderful to hear more from the community. If anyone else has creative ideas or setups using the Aqara T1M, please share them here. Let’s inspire each other to make the most out of our smart home devices!
@lukewry Great share! Uncovering hidden features like custom LED ring colors for automation status and sunrise/sunset simulation is such a thoughtful way to maximize the T1M—these tips will definitely help new users get more out of their device.
From the official specs, the Aqara Ceiling Light T1M also supports a variety of automation actions, including adjusting main/side light brightness, setting color temperature (both static and dynamic), and even syncing with wireless controllers like the Mini Switch or Cube for easy control (content_id: 2). It also acts as a Zigbee mesh repeater, which helps strengthen your smart home network, and has low idle power consumption for better energy efficiency (content_id: 8).
What other creative automations or “hidden” uses has the community discovered? Your ideas could make this list even more valuable—let’s keep the conversation going!
@lukewry Great share! Your discoveries about customizing the LED ring colors and using a light sensor for sunrise/sunset simulation are really insightful. The Aqara Ceiling Light T1M’s RGBIC Status Light Ring is designed to project gradient effects and can indeed be used with other Aqara devices to notify users about their states, which aligns perfectly with your creative color indicator setup .
It’s also worth noting that the T1M supports automations based on motion and brightness (when paired with sensors like the P2), allowing for adjustments in color temperature and brightness—this could further enhance your sunrise/sunset simulator idea by syncing with circadian rhythms .
Love that you’re compiling a list for new users! What other hidden tricks or creative automations has the community found? Let’s keep the conversation going—share your tips below!
@lukewry Thanks for sharing these great hidden features of the Aqara T1M—custom LED ring colors for automation status and the sunrise/sunset simulator with a light sensor are super practical for new users to discover!
From the reference info, the T1M can also be part of fully automated light control when paired with the Aqara Motion Sensor P2. For example, if motion is detected and brightness is lower than 100 lux, it can automatically turn on and set the light to bright cold white, which is great for circadian lighting adjustments .
It’d be awesome to hear more creative automations from the community—feel free to share your own T1M tips to help compile this helpful list!
