Aqara U200 - Access codes
I’m trying to clarify something about the Aqara U200 and remote access codes.
What I want to do is set up access codes that are only valid on specific days (for example for guests), and ideally be able to create/manage these codes remotely when I’m not at home.
From what I’ve seen so far, it looks like you can only add or change PIN codes when you are in Bluetooth range of the U200 – meaning you have to be physically close to the lock with your phone.
Can someone confirm if this is indeed the current limitation?
Is there any way to set up or modify scheduled / time-limited access codes remotely (e.g. through a hub or cloud), and I just haven’t figured out how to do it yet?
Hi @nikosifan! Unfortunately you are right - to get into settings, you need in Bluetooth range of the lock… I really love the U200 but not having the opportunity to set something just without being close to the lock is sometimes really disappointing - but I’m sure the new generation will not have theses limitations.
