Hi everyone. I wasn’t sure how to explain it in the title.
My front door is configured so that if I insert the key on one side, I can’t insert it on the other. Or rather, I can insert it, but it won’t turn if there’s another key in the opposite lock.
If I understand correctly, the Aqara U200 is installed with the key inserted, since the device “turns the door’s original key.” However, in my case, if the battery dies, it means I can’t get in from the outside because I can’t use the physical key on the other side.
Is this correct, or am I missing something?
Thanks.
