Hello, I want to buy the U200Lite lock and I’d like to know if it’s possible to set a specific time for a key? For example, giving the key to the maid to open the door between 9 am and 1 pm?
Thanks
@miguellandre Hey there! Great question — and yes, the U200 Lite has you covered for this exact scenario.
Based on the U200 Lite’s feature set, it supports periodic passwords that you can set for specific time windows and recurring days. So for your maid example, you could create a password that only works from 9 AM to 1 PM on whichever days you need — no manual key handoff required.
A couple of things to keep in mind:
- The U200 Lite primarily uses Bluetooth proximity unlock via the Aqara app and NFC Sticker Card for everyday access, rather than a physical keypad. This means periodic passwords would typically be managed and shared through the Aqara Home app.
- For remote management (like setting or modifying these passwords while you’re away), you’d want to ensure the lock is connected to a compatible Thread border router or hub.
If you need the full keypad experience with direct PIN entry, the standard U200 might be worth comparing — it explicitly supports up to 75 passwords including periodic ones, with 6-10 digit codes and anti-peeping features.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Hope that helps with your decision — feel free to ask if you want to dig deeper into the U200 vs U200 Lite differences
Thank you for the information.
