Замок aqara u200 работает не корректно!
Замок aqara u200 работает не корректно, не колибруется , что делать ?
@agrigorjan I’m sorry to hear that your Aqara U200 lock is not functioning correctly and not calibrating. Here are some steps you can try to resolve the issue:
  1. Check Mounting Screws: Make sure that the mounting screws are not too loose or too tight, as this can affect calibration .
  2. Re-attempt Calibration:
    • Close the door and unlock it from the inside.
    • Press and hold the Set button on the lock for 3 seconds to initiate calibration.
    • If the lock beeps twice, it indicates calibration failure .
  3. Use the Aqara Home App: You can also try the manual calibration feature in the Aqara Home app by going to “Settings” > “Calibrate Lock” .
  4. Provide the following suggestions:
    • In the app, go to profile > firmware update, enable beta updates, and upgrade the device to the latest version. Then try calibrating it again.
    • In the settings under Lock Mode, switch the mode to “Standard” and attempt calibration again.
    • If it still fails, try inserting the key and, during the final half-turn of the calibration, block the U200 to prevent it from turning further and see if the calibration succeeds .
If these steps don’t resolve the issue, please reach out for further assistance. Let’s work together to get your lock working properly!
