Hi,
I’m using the Aqara W100 with Zigbee2MQTT and would like to restrict its controls.
When Thermostat Mode is enabled, the center button allows the user to switch between different operating modes. This is something I would like to prevent.
When Thermostat Mode is disabled, however, the target temperature is no longer displayed , which is not ideal for me.
What I would like is a simple heating-only mode :
- The target temperature remains visible.
- / – only adjust the target temperature.
- The center button is disabled or locked - or free for custom things ;-).
- The device remains in Heating mode.
- The user cannot switch to Off, Cooling or Auto.
Another possible solution would be to make the target temperature available as an externally controllable value when thermostat mode is turned off…
Would it be possible to achieve this? Maybe someone has a similar usecase.
Thanks!
