Aqara W100 Thermostat
I want to use the W100 and Aqara automations to build a home thermostat for my central heating (UK boiler). Currently I just have an automation that switches the heating if the temperature is above/below a setpoint. However this means to change the temperature setting I need to change the automation.
Can you please expose such a feature on the W100 - some event/status when the temperature is above/below an adjustable setpoint - then I can use that event/status in my automation.
The device has not yet gone on sale on the global market, it will be known when it will start selling.
There is a vietnamese review where most screens were shown, I could not see these features supported.
Hi there, it sounds like a great idea.Let’s evaluate it.
I purchased a W100 and there is no such trigger for me to make an automation to control my boiler.
I’m going to return the W100.
I’m very disappointed - it would be such a trivial easy feature for you to add and if you did it, you could compete with Tado and Nest.
How do you currently control the temperature of your boiler? Do you have a smart controller for your boiler? Nest currently requires two devices—a remote control unit (which just like W100)and a unit connected to the boiler—to enable this scenario.
Hello, I use the Aqara T2 relay, the dry contacts of which start the boiler. In conjunction with this relay, I use a thermal head that is controlled by the Aqara relay on each battery and monitored by the Aqara temperature sensor. If you are interested, I can thoroughly tell you how I organized the control of heating automation.
I’ve built a fully automated seasonal system for my heat pump using only the Aqara.
Each season (Summer, Winter, and Spring/Fall) has its own set of three automations:
One for when we’re Home
One for when we’re Away
One for Night time
These are triggered based on the Aqara Security System mode (Home, Away, or Night).
In addition, I created three simple automations based on the outdoor temperature that take care of enabling or disabling the right seasonal profiles:
One automation activates the Summer automations when it’s above 17 °C
One activates the Winter ones when it’s below 0 °C
One handles the Spring/Fall set when the temperature is between 0 °C and 17°C
Each of these automations also disables the automations from the other seasons, so only the relevant ones are running at any time.
It works great and saves me from manually switching profiles as the weather changes.
I have a conventional wireless, non-smart, boiler thermostat from Valiant. To your question - boiler ā€˜temperature’ is not controlled. It is on/off.
It is only via opentherm or ebus that one can independently control boiler water temerature. I am NOT asking for that here. All boilers can be controlled in an on/off manner, and many nest/tado installations have to control the boiler in this way, because many boilers in the UK are old and only support on/off control.
Anyway - back to my use case.
In parallel to that I use a T2 relay to also fire the boiler for some automations (like turn on for 30 mins after shower to warm the towel rail)
If you simply exposed an automation trigger for the W100 for when it is above/below the set temperature then I could use that instead of the Valiant unit. It’s a trivial addition and then you could complete with nest (T2 + W100 + automation = nest)
Somewhere information leaked that Aqara plans to make an external wall thermostat, maybe it will have such a function as you say. I also lack such a function in the W100, but the ability to select the sensitivity of the thermometer impresses me and helps in controlling the room. I also like additional information about the temperature of the selected thermometer. And to do as you say, I use an inactive TVR Aqara, tying it to it and select the function ā€œbelow the setā€ or ā€œabove the setā€ and control it that way.
One feature, such automation is always CLOUD (.
@XT-XianTang
I am worried from your other replies that you think I am suggesting electrical changes to the W100. I am not.
I only need you to fix the firmware so I can make an automation if the W100 temperature is above / below the the set temperature. You have many triggers on the W100 already, I just need this extra one which is missing.
I think changing the firmware won’t help. We need a new product that takes our suggestions into account :slightly_frowning_face:
Sorry @gafich10 then you misunderstood my specific request. Please don’t make the request larger than it needs to be or else they will never do it.
An automation trigger as I described would be enough for a on/off boiler adjustable thermostat in conjunction with a simple relay.
They could do a firmware update in 1 month. A new product is not going to be ready before winter.
Hello, I agree with you 100% and for this request for an additional function to be made for the W100 with the help of a firmware update. I currently have 3 W100s.
I’m just afraid that the W100 sensor lacks a (unplanned) microcircuit that can perform the function we want for the W100.
Dear Aqara employees - has there been any updates on this simple request?
We have already completed the configuration of this automation.
You can try it out, but please note that this feature uses the Zigbee protocol.
This is not what I mean - I’m confused why my request has been misunderstood again!
The ā€˜set’ temperature is the one which is is controlled by the +/- buttons on the device.
You have shown a screenshot showing an automation which is above or below a ā€˜specified temperature’ which is set in the automation.
This is not what I mean - in your screenshot if my wife wants to change the temperature she must edit the automation
I simply want to use the W100 like a normal thermostat, so you adjust the termperature using the +/- buttons
@XT-XianTang do you understand what I mean? maybe you attached the wrong screenshot? or maybe you dont understand what I mean?
Can I understand it as follows: after associating the device, you can use the +/āˆ’ buttons to adjust the target temperature, and the system will automatically adjust the automation settings based on the current temperature?
For example: if the set temperature is higher than the target temperature, the air conditioner will turn on.
If that’s the case, this functionality is currently not supported by our system.
Thank you. You have almost understood. I know the feature is not supported by your system, that is why I keep asking for it here, and on other threads.
The feature is not that the button press should adjust the automation. It should have an automation trigger like in your screenshot that is ā€œcurrent temperature is above the set temperatureā€.
This feature should work if the W100 is not associated with anything. All you need to do is expose one new automation that is based on the the set temperature relative to the device temperature in all situations. It should not need to be associated with a device.
If that is added then the W100 can be used as a central heating (boiler) thermostat and can compete with Tado / Nest by writing a simple automation which uses a relay to switch central heating on or off.
I should say that this is an extremely important feature request. It could make the device very useful. Currently, it hasvery limited applicatiuon. Too limited.
My use case is the same. I want to use the W100 as a trigger to operate a T2 relay or a smart socket. The user could specify the target temperature using the hardware buttons on the W100. The automation would then turn on or off if the current temperature is less than or more than the user-specified target temperature (without using a smartphone application).
This would only require a software modification on side of Aqara.
Currently, such a scenario is only possible with the M3 and E1. If Aqara adds support for relays and sockets, it will be possible to use the W100 as a normal thermostat without an external power source. This would make the device useful in many new scenarios.
Please, Aqara, make this small software improvement :slight_smile: I need this automation! This is for anybody who has underfloor heating with liquid coolant and cannot install a W500 in the wall.
