Hello, I’m currently using the W200 for a conventional AC with a furnace. I’m considering upgrading my home with several mini-splits and wanted to see if the W200 can be paired with at least one to control.
The W200 isn’t likely the best device for this because the mini splits usually don’t use external wired thermostats, but have their own internal controls.
Then they use IR enabled remotes for temperature control. That said, you could use the M3 hub as a Matter HVAC controller as a replacement for the remote.
