Hello, even after a factory reset and restarting the Aqara W600, the thermostat keeps calibrating indefinitely without completing the process. What could be causing this issue? Could you also tell me how far the internal motor-driven pin extends to press the radiator valve pin? I suspect it may not reach the radiator valve, so I would like to check whether this could be the cause of the calibration failure. Thank you for your help
Hello, welcome to the forum. I have an idea. I ran into an issue programming the W500; it didn’t work when I used an Android device, but everything went fine when I used an iPhone. Perhaps you could try that. I also recommend contacting customer support.
support@aqara.com
Thank you for your reply. I am already using an iPhone. I successfully added the Aqara W600 to the Aqara Home app and configured it, but the calibration always got stuck. I then completely removed the device from the app, performed a factory reset and started the installation again from scratch. I powered on the thermostat, screwed it onto the radiator valve without any problems (the thread fits perfectly), and pressed the button three times to start calibration. F2 started flashing as expected, but the calibration still never completed. I suspect that the internal motor-driven pin, which is supposed to extend and press the radiator valve pin, is not moving at all. Could this be a hardware issue with the thermostat?
I wouldn’t necessarily call it a hardware issue. Try removing the W600, switching to Thread, and then switching back to Zigbee. That worked for me once.
Sometimes the device can be stuck in F2 if it’s not mounted properly. Do you use any adapters?
I don’t think an adapter is necessary, as the mounting nut fits perfectly onto the radiator valve and can be tightened without any problems. However, I suspect that during calibration, the internal motor-driven pin either does not extend at all or does not extend far enough to press the radiator valve pin. I even tried running the calibration with the thermostat removed from the radiator, and I couldn’t see the internal pin extending. Could this be the reason why calibration always gets stuck on F2?
Yes, that might be a reason. You might try putting a small coin or two to help the pin (I think there was also some extension to the pin included in the box, or was it the older Aqara radiator thermostat?).
Btw what’s your thermostat valve standard? I have the Danfoss RTD-N, so I had to 3D print an adapter (it’s almost like M30x1.5, but the center part sticks out more).
Exactly, put a small coin like 1 cent between pin inside - and start calibrating again- that should solve it
