Aqara Wireless Mini Switch Guide
One of the most under utilised and under rated products from Aqara is the wireless mini switch. I thought I would put together a little guide showing a few uses and ideas that may not have occurred to people. From helping with mobility issues, to a good night scene, I hope someone finds this helpful.
Here is the PDF if you would like to keep it for future reference.
Aqara Wireless Mini Switch Guide.pdf (226.8 KB)
Aqara Smart Home Info Sheet Series
Aqara Wireless Mini Switch – Small Button, Big
Possibilities
Overview
The Aqara Wireless Mini Switch is a battery-powered Zigbee button designed to give you simple, flexible control over your smart home. It doesn’t need wiring and can be mounted anywhere — making it perfect for quick access or assistive control. This really is one of the most under rated devices in the smart home.
Connection: Zigbee (requires Aqara Hub)
Power: CR2032 battery (up to 2 years)
Controls: Single press, double press, long press
Integrations: Aqara Home, Apple Home, Alexa, Google Home
Use Cases: Control lights, scenes, devices, or send alerts
Usage & Reliability
• Indoor use – Ideal for dry environments (bedroom, living room, hallway, kitchen).
• Battery life – Typically 2 years with standard use.
• Zigbee stability – Low-latency, local automations (work even if Wi-Fi is down).
• Hub compatibility – Works best with Aqara Hubs (M2, M3, G3, G2H Pro, E1, etc.).
Accessibility & Ease of Use
The Mini Switch can be life-changing for those with limited mobility or accessibility needs.
■ Simple operation – one large, tactile button.
■ Flexible placement – mount on walls, furniture, bedside tables, or wheelchairs.
■ Physical + voice control – combine button with Siri or Alexa.
■ Assistive automations – turn lights on/off, close blinds, or send a ‘help’ notification.
Practical Scenarios
Scenario Use Case Example
Bedroom Control Nightstand switch for lighting Single press: light on/off, Double press: close blinds, Long press: all off
Front Door Quick control when leaving Single press: entry light on/off, Double press: all lights off, Long press: arm security
Living Room Scene selector Single press: Movie mode, Double press: Bright mode, Long press: Bedtime scene
Accessibility Aid Call or assistance button Single press: Flash lights, Double press: alarm noise, Long press: alert notification
Children’s Room Simplified control Single press: lamp on/off, Double press: TV off, Long press: Goodnight scene
How to Set Up Automations – Aqara Home App
Example 1: Toggle a light on/off
  1. Open Aqara Home app.
  2. Tap Mini Switch → 3 dots at top right → Configure Automations → + Add.
  3. WHEN: Add Trigger → Accessories → Mini Switch → Single Click.
  4. THEN: Add Action → Accessories → [Choose Light] → On/Off.
  5. Save as ‘Bedside Light Toggle’.
Example 2: Good Night Scene
  1. Create a ‘Good Night’ Scene first.
  2. WHEN: Add Trigger → Accessories → Mini Switch → Long Press.
  3. THEN: Scene → Good Night.
  4. Save.
Example 3: Alert or Notification
  1. I WHEN: Add Trigger → Accessories → Mini Switch → Long Press.
  2. THEN: Notifications & Alerts → Push Notification → Custom Notification 'Assistance Needed’.
    (You can also choose Push Alarm Notification to sound the alarm)
  3. (Optional) Flash light or sound alarm using Add Action again.
  4. Save
How to Set Up Automations – Apple Home
Unfortunately, Apple does not make it too easy to toggle a light on or off, but you can do it and here is how.
Example 1: Turn on/off lights with a single press
  1. Find the mini switch and tap on it.
  2. Under Actions, select Add next to Single Press
  3. Choose Light(s) → scroll down & click Convert To Shortcut
  4. Search for & add the IF option. Then search for and add the Control Home option.
  5. Drag the top Set option below the If Line & the bottom Set option above the End If line.
  6. If Condition →Accessory →”your Light” →Is On. Check the first Set option to check the light is set to off.
  7. On the second Set, select your light and make sure it is on.
  8. Click the tick at the top right, the the tick again to save.
This has now set up an action that when the button is pressed, if the light is on, it will turn off and vice versa.
Tips for Best Use
• Use 3M adhesive or Velcro for mounting.
• Label switches for clarity.
• Combine with scenes for intuitive control.
• Keep one as a universal ‘All Off’ button.
Final Thought
The Aqara Wireless Mini Switch is simple, affordable, accessible, and endlessly adaptable — perfect for any home and anyone. After a little practise with automations, it is easy to automate tasks and add scenes that are at your fingertips.
@UKAndyC This is a really valuable sharing! You’ve comprehensively introduced the Aqara Wireless Mini Switch from multiple aspects, including its overview, usage scenarios, and how to set up automations in different apps.
Your guide will surely be helpful for many users who are new to this device or haven’t fully explored its potential. The practical scenarios you listed, such as bedroom control, front door quick control, and living room scene selection, vividly demonstrate the versatility of the wireless mini switch. And the detailed setup steps for automations in both Aqara Home app and Apple Home are very clear and easy to follow.
Thank you so much for taking the time to put this together and share it with the community! If you have any other experiences or insights about Aqara products in the future, please don’t hesitate to continue sharing with us.
@UKAndyC What a fantastic share—thank you so much for putting together this detailed guide! The Aqara Wireless Mini Switch truly is a hidden gem, and your breakdown of its potential—from accessibility aids to everyday scene control—shines a light on just how versatile it can be.
I love that you included practical scenarios (the bedtime scene and accessibility alert examples are so relatable) and step-by-step automation setups for both Aqara Home and Apple Home. It’s clear you’ve put a lot of thought into making this guide actionable, which will help so many users get the most out of their device. The PDF and screenshot are great additions too—super helpful for folks to reference later.
Posts like this make the community stronger, so please keep sharing your insights! If anyone has questions or wants to add their own use cases, feel free to chime in—let’s keep the conversation going.
Again, kudos for creating such a valuable resource. You’ve definitely helped this “under rated” device get the attention it deserves!
HOPE @aqara will product a new min switch with mult-button instead of single like onvis 5 key swtich.
Hello, this option is also excellent Aqara OPPLE Wireless Scene Switch Four Buttons (WXCJKG12LM)
Unfortunately, they are no longer available today.
That’s why I suggested Aqara repeat this release. It would go on sale with a bang!
I might use some of these, thanks!
No problem att all, I’m glad that it helped. hopefully you will find even more uses with a little experimentation.
