Hey everyone, I’m thrilled to share my recent journey into the world of Arduino and Home Assistant integration!
I’ve been experimenting with creating a multi-switch button box using an Arduino Uno and an RF433 module to control my living room lamps connected to generic outlets. It’s been a fascinating learning experience, though not without its challenges. ![]()
Here’s a quick overview of my setup: I’ve programmed the Arduino to send specific RF codes to toggle each lamp on and off. The code includes functions for individual lamps and even a group control for all lamps at once. While I’m proud of what I’ve achieved so far, I’m eager to take it to the next level by integrating it seamlessly with Home Assistant.
One of my main goals is to allow Home Assistant to read and update the state of each lamp directly from the Arduino. However, I’m currently stuck on figuring out the best way to establish communication between the Arduino and Home Assistant. I’ve heard that MQTT could be the solution, especially since I recently purchased two ESP8266 modules to potentially handle the wireless communication. Should I modify my existing Arduino code to work with MQTT, or would it be better to offload the RF433 functionality to my Raspberry Pi and use the Arduino solely for switch inputs? I’m open to any suggestions or insights! ![]()
I’m also considering whether to stick with my current approach or explore alternative methods, such as using Home Assistant’s built-in automation features with the ESP8266 modules. The idea of having real-time state updates from the Arduino to Home Assistant is incredibly appealing, as it would allow for a more integrated and responsive system.
If anyone has experience with similar projects or can offer guidance on the best way to proceed, I’d be incredibly grateful! Whether it’s advice on code optimization, hardware configuration, or integration strategies, your input would be invaluable. Let’s make this project a success together! ![]()
Thanks in advance for your support and wisdom. Happy coding and integrating! ![]()
