I recently set up the Argon One cooling system for my Raspberry Pi setup, and I wanted to share my experience and some tips for anyone looking to do the same. The Argon One cooling system is a game-changer for keeping your Raspberry Pi cool, especially if you’re running it in a high-performance setup or in a warm environment.
First, I installed the Argon One Active Cooling Addon in Home Assistant. This addon allows you to automate the cooling system based on temperature thresholds. I found it incredibly easy to set up, even with my limited experience. The addon provides two options: Active Cooling and Active Linear Cooling. I went with the Active Cooling option since it closely mimics the stock Argon One scripts, which I felt would be more reliable for my use case.
One thing I learned is to carefully configure the temperature ranges. The default settings are 55°C for LowRange, 60°C for MediumRange, and 65°C for HighRange. I adjusted these to 50°C, 55°C, and 60°C respectively to provide a bit more headroom for my setup. This adjustment ensures that the fan kicks in a bit earlier, preventing any potential overheating issues.
I also played around with the Quiet Profile setting. Initially, I had it turned off, which means the fan operates at 33%, 66%, and 100% duty cycles. However, I found the noise level a bit intrusive, especially during quiet evenings. So, I enabled the Quiet Profile, which reduces the fan’s duty cycle to 1%, 3%, and 100%. This significantly降低了噪音,同时仍然保持了有效的冷却效果。
Another thing I discovered is the importance of enabling I2C. Without I2C, the addon couldn’t communicate with the Argon One board, and the fan wouldn’t start. I followed the instructions to enable I2C through the HassOS I2C Configurator addon, which made the process straightforward. Just remember to reboot your system after enabling I2C to ensure the changes take effect.
Overall, I’m extremely satisfied with the Argon One cooling system and the Home Assistant addon. It has made my Raspberry Pi setup much more reliable and quieter. If you’re considering upgrading your cooling system, I highly recommend giving the Argon One a try. Just take the time to configure it properly, and you’ll be rewarded with a much smoother and cooler experience!
Happy cooling! ![]()
