I wanted to share my recent experience with my August smart lock, as it turned out to be quite an adventure! Hopefully, this story can help someone else avoid the same frustration.
The Problem:
My August lock (with built-in Wi-Fi) was allowing me to unlock but then immediately thinking it was locked again. This meant I couldn’t lock it properly, and tapping on the lock icon just led to timeouts. It was incredibly frustrating, especially since I rely on my smart lock for security.
The Journey to a Solution:
I reached out to August’s tech support multiple times, and while they were helpful, the issue persisted. I tried everything from resetting the lock to manually adjusting it, but nothing worked consistently. It seemed like a communication problem between the lock and the August system.
The Breakthrough:
After several days of troubleshooting, I decided to send an email directly to August’s support team. To my delight, someone replied with incredibly detailed advice that pinpointed the issue: calibration. It turns out the lock’s tailpiece wasn’t aligned correctly with the adapter, causing the lock to malfunction.
The Fix:
Here’s what worked for me:
Identify the Adapter Color:
- Yellow Adapter: Tailpiece must be diagonal when locked ( / or \ ).
- Blue Adapter: Tailpiece must be horizontal ( - ) or vertical ( | ).
- Green Adapter: Tailpiece must be D-shaped.
- Red Adapter: Tailpiece must be thick and rectangular.
Calibrate the Lock:
- Physically lock your door and remove the August lock.
- Check the tailpiece alignment and ensure it matches the correct adapter type.
- Reinstall the lock and access the lock settings in the August app.
- Follow the on-screen instructions to calibrate the lock.
Test and Repeat if Necessary:
- After calibration, test the lock multiple times to ensure it works correctly.
- If issues persist, repeat the calibration process or refer to additional guides (like this YouTube video).
The Result:
This fix was a game-changer! My lock now works perfectly, and I can confidently rely on it again. The support team at August deserves a huge shoutout for their patience and expertise.
Final Thoughts:
If you’re experiencing similar issues with your August lock, don’t give up! Take the time to check the alignment of your tailpiece and adapter, and don’t hesitate to reach out to August’s support team. With a little troubleshooting and the right guidance, you’ll be back to enjoying the convenience of your smart lock in no time.
Happy locking (and unlocking)!
