I’ve been working on a project to automate my window shades based on cloudiness detection, and I thought I’d share my journey and solution with the community. The goal was to create a system that adjusts the shades automatically without relying solely on weather forecasts, which I found to be inconsistent for my needs.
The Challenge:
Detecting cloud cover accurately and efficiently was the primary challenge. I wanted a solution that could work year-round, detect cloud levels quickly, and be cost-effective. After some research, I settled on using illuminance (lux) measurements as the basis for my system.
The Solution:
I decided to use the Philips Hue outdoor sensors, which are battery-driven and wireless, making them ideal for placement around my house. I placed three sensors in strategic locations to cover different directions. Each sensor measures the lux level, which is transmitted every 5 minutes to my OpenHAB system.
The Setup:
- Sensors Placement: I positioned the sensors to face east, south, and west to ensure comprehensive coverage throughout the day. The south-facing sensor required a slight modification to account for the sun’s angle.
- Data Processing: The system calculates a ‘Cloud Index’ by normalizing the lux measurements against the theoretical maximum sun radiation on a vertical surface. This index is then used to determine the cloudiness state: ‘Sunny’, ‘Partly Cloudy’, or ‘Cloudy’.
- Automation: The cloudiness state is fed into a fuzzy logic system to control the shades. A hysteresis of 15 minutes is implemented to prevent frequent adjustments due to passing clouds.
Results:
This setup has been running smoothly for several months now. It not only provides accurate cloud detection but also integrates seamlessly with my existing smart home ecosystem. The system is self-sufficient, requiring minimal maintenance beyond occasional battery checks.
Tips and Tricks:
- Sensor Placement: Ensure sensors are placed in sunny spots and oriented correctly to capture accurate readings.
- Calibration: Spend time calibrating the sensors and adjusting the threshold values to match your local conditions.
- Fuzzy Logic: Using fuzzy logic helps in making the system more robust against sudden changes in cloud cover.
I’m really happy with how this project turned out and would love to hear from others who have implemented similar solutions or have suggestions for improvements. Let’s continue to innovate and share our experiences to make our smart homes even smarter!
