I’ve been exploring ways to automate my garage door to ensure it closes securely every night. After some research, I decided to use a combination of Zooz Z-Wave Plus Relay and Shelly devices to achieve this. Here’s how I set it up and what I learned along the way! The Challenge: My garage door is often left open during the day, but I want it to close automatically at night for security. I also wanted to keep it open during the day without manual intervention. After some trial and error, I found that using an automatic door closer paired with a magnetic door holder was the perfect solution. The Setup: I installed a Zooz Z-Wave Plus Relay to control the magnetic door holder, which keeps the door open during the day. At night, the relay disengages the holder, allowing the automatic door closer to shut the door securely. This setup integrates seamlessly with my existing smart home ecosystem, including Zigbee and Z-Wave networks. Key Insights: - Device Compatibility: The Zooz relay was a game-changer. It allowed me to control the magnetic holder without any issues. - Automation Rules: I set up a simple automation rule in my smart home hub to engage the magnetic holder in the morning and disengage it at night. - Flexibility: The system is incredibly flexible. I can manually override the settings if I need to keep the door open longer or close it earlier. Tips for Others: - Start Small: Begin with a basic setup and gradually add more features as you become comfortable. - Test Thoroughly: Ensure all components work together before fully automating the system. - Consider Future Needs: Think about how you might expand the system in the future, such as adding additional sensors or integrations. This project has been a great learning experience and has significantly improved my home’s security. If you’re looking to automate your garage door, I highly recommend exploring similar solutions! ![]()
