Automating Kitchen Lighting with Aqara Vibration Sensor
I’ve been exploring ways to enhance my kitchen lighting experience, and I stumbled upon an interesting challenge that I thought I’d share. I want to set up my kitchen lights to automatically adjust to a brighter setting whenever I open the dishwasher door. Sounds simple enough, but there’s a catch—I don’t want to manually toggle the light switch every time, which feels a bit outdated in this smart home era!
I’ve got an Aqara Vibration Sensor that includes a tilt function, which I thought could be perfect for this task. The idea is to trigger a brighter light setting when the dishwasher door is opened. However, I’ve been struggling to get the right settings in place with my Logic app. The sensor detects the tilt, but I can’t seem to get it to send a consistent Boolean value—true when the door is open and false when it’s closed. I’ve spent a few hours tweaking the settings, adjusting the tilt angles, and testing different flows, but it’s just not working as smoothly as I hoped.
Here’s what I’ve tried so far: I set the tilt angles to correspond to the door’s positions. When the door is fully closed, it’s at -77 degrees, and when it’s fully open, it’s at 5.16 degrees. I figured if I could get the sensor to recognize these positions accurately, I could map them to the light settings. But no matter how I adjust the thresholds, the sensor either doesn’t trigger the light change or does so inconsistently. It’s frustrating because the potential is there, but I’m just not hitting the right configuration.
I’m curious if anyone else has tackled a similar project or has some tips on how to refine the tilt settings or the logic flows. Maybe there’s a way to fine-tune the sensor’s sensitivity or adjust the angle thresholds more precisely. Any advice or suggestions would be greatly appreciated! I’m determined to crack this and make my kitchen lighting smarter and more convenient. Let’s see if we can make this automation work!
