I’ve always been a bit of a tinkerer, and when I decided to start growing my own veggies, I knew I wanted to incorporate some smart tech into the mix. So, I came up with this project to automate my garden’s irrigation system using Wyze devices. It’s been a blast, and I thought I’d share how I did it in case anyone else wants to give it a try!
The Setup
I started by getting some 5-gallon buckets from the local hardware store—one for each plant and one for the water reservoir. I attached a simple water pump to an irrigation hose and connected it to a Wyze Plug so I could control it remotely. To monitor the water level, I used a piece of noodle as a float and attached a Wyze Cam to keep an eye on everything. Talk aboutDIY ingenuity!
The Automation
Where things got really fun was when I added a Wyze Door Sensor to the float. Now, whenever the float detects that the reservoir is low, it triggers the Wyze Plug to activate the pump for a specific amount of time. I even set up the Wyze Cam to take timelapse videos, so I can watch my plants grow over time. It’s like having my own little garden documentary!
The Challenges and Solutions
At first, I was worried about the pump not delivering enough water, but after some trial and error, I figured out the perfect timing. I also had to make sure the float was positioned just right so it wouldn’t get stuck. A bit of tweaking here and there, and everything started running smoothly.
The Results
Best of all, my plants are thriving! I don’t have to remember to water them every day, and they’re getting the exact amount of water they need. Plus, using rainwater means they’re getting all the nutrients they need without any chemicals from the tap. It’s been a win-win for both me and my garden.
If you’re looking for a fun project that combines gardening with smart tech, I highly recommend giving this a shot. It’s a great way to learn a bit more about your devices and get creative with how you use them. Happy tinkering! ![]()
