Automating My Irrigation System with Smart Sensors and Rules
Hey everyone, I’m really excited to share my recent project where I automated my garden irrigation system using smart sensors and some clever rules. I’ve been wanting to do this for a while, and finally, I took the plunge. Let me walk you through how I did it and what I’ve learned along the way.
The Goal
My main objective was to ensure my plants get the right amount of water without me having to manually check the soil every day. I wanted a system that could monitor the soil moisture and automatically turn on the sprinklers when needed. Plus, I wanted it to be energy-efficient and not waste water.
The Setup
I started by researching the best soil moisture sensors available. After some reading, I decided on the Robuster Bodenfeuchtesensor für den Ausseneinsatz mentioned in one of the forum posts. It uses a clever Wechselstromverfahren to measure soil moisture without causing corrosion, which is perfect for long-term use. I installed two of these sensors in different parts of my garden to get accurate readings.
Next, I connected these sensors to my Shelly 1 smart switch. This allowed me to control the sprinkler system remotely and set up some automation rules. I also integrated my garden lights so they turn on when the sprinklers activate, giving me a nice visual cue that everything is working as it should.
The Automation Rules
Here’s where things got really interesting. I set up a few rules in my smart home system to handle the irrigation:
  1. Moisture-Based Watering
    • If the soil moisture drops below 20%, the sprinklers turn on for 5 minutes.
    • After watering, the system waits for 30 minutes to let the water absorb before checking the moisture again.
  2. Time-Based Override
    • To prevent overwatering during rainy periods, I added a condition that skips watering if it has rained in the last 24 hours. I used my Wyze Weather Station to track rainfall.
  3. Energy Efficiency
    • The system only waters between 6 AM and 8 AM to avoid evaporation during the heat of the day.
The Results
So far, the system has been a huge success! My plants are thriving, and I’ve noticed a significant reduction in water usage compared to my old manual system. The sensors are incredibly accurate, and the automation rules have made everything seamless.
Challenges and Learnings
Of course, it wasn’t all smooth sailing. I ran into a few issues along the way:
  • Sensor Calibration: The initial readings from the sensors were a bit off. I had to manually adjust them a few times before they gave accurate data.
  • Rule Logic: Getting the automation rules just right took some trial and error. I had to tweak the timing and conditions a few times to ensure everything worked harmoniously.
Tips for Others
If you’re thinking about automating your irrigation system, here are a few tips:
  • Start Small: Don’t try to automate your entire garden at once. Start with a small section and perfect the system before scaling up.
  • Quality Sensors: Invest in good quality sensors. They make a huge difference in the accuracy of your system.
  • Regular Maintenance: Check your sensors and sprinklers regularly to ensure everything is working as it should.
This project has been a fantastic way to combine my love for gardening with my interest in smart home technology. It’s been incredibly rewarding to see how a bit of planning and some clever automation can make such a big difference. I’m already brainstorming my next smart home project—maybe automating my compost system next!
If anyone has questions or wants to share their own automation projects, I’d love to hear from you. Happy automating! :seedling::droplet:
