Hi there, is there a please an option for automation to trigger another automation in Aqara ecosystem?
I have a complex automation that is linked to a light switch button press. I have a second light switch and instead of copying the whole automation where I would just change the switch to do the same set of actions, I would like to create a new automation where I configure the second switch to start that old automation…
I haven’t found a way to do that. For example, I cannot invoke a button press of another switch by an automation (only to turn the relay on/off which I don’t want).
Upon checking you are right. No option to run a automation within a automation. Only scenes. Feel free to take screenshot of the automation an I will take a look.
Of course. Anything you add to the “Then” section in an automation can also be part of a scene. And instead of running the actions individually within the automation, you simply trigger the scene. The only difference between automations and scenes is the “If” part.
