Hi - I’m using the Aqara automation engine with my Aqara Motion and Light Sensor P2 to turn on/off my matter LIFX downlights. Is there a way to turn the lights on/off smoothly? I dont like the jarring effect when the lights turn on/off instantly. I can do it in the LIFX app on a schedule but can’t figure out how to do it in an automation. Thnx.
Hi, instead of time of day, use “lamp on”
here the matter is a little different, as I understand it, a smooth ignition of the LEDs is needed when turning the light on/off; if you set a minimum delay of 1 second, this will not be the same effect; this is in the light bulb settings.
Agreed. Aqara T2 led bulbs have that and it does make a difference. Unfortunately, LIFX bulbs do not.
