Automation via Aqara AI using the example of remote control and IR code
In order for IoT devices to be widely accepted by everyone, it is essential that they are easy to integrate and interact with, and that the system is open to other manufacturers. Platforms such as Apple’s Homekitt with “Shortcuts” offer powerful cross-manufacturer automation that supports not only IKEA’s Trådfri and Dirigera components, but also Zigbee light switches and smart lamps with a good CRI90 value, as well as Aqara components. This enables an affordable, subscription-free and self-sufficient system that can grow to over 100 components over time when climate control and presence control are added. This can save several hundred pounds a year in electricity and energy costs while also increasing comfort.
Important for this is cooperation with access not only to the IoT device but also to the extended control options of the respective apps. As one of the few hubs, Aqara’s G3 hub has an integrated IR remote control. The signal reaches even unfavourable positions, e.g. on the streamer, active speaker and TV. This means that, for example, the IR activation of the speaker and streamer as well as a favourite stream can be started on the Aqara Cube, and by turning the cube further, you can switch to the next stream without having to reach for your smartphone or watch. With the additional integration of wireless sockets with a programmed time delay until the WLAN/BT connection is established, standby power costs can also be saved.
The programming of Aqara’s automations and the creation of an Aqara remote control layout have one thing in common: their time-consuming programming, which even interested parties shy away from. The solution: an AI assistant that programmes the desired tasks in a guided question-and-answer format and, in addition to voice input, also uses the smartphone camera to digitise the physical remote control based on the photo taken, and then makes it available as a virtual remote control in the Aqara app. Thanks to standardised remote control button symbols and the input of the device model, the AI can independently transfer their function with the corresponding IR code from the web database to the layout, and only request teaching if IR codes are missing. The availability of less common device remote controls will grow as Aqara stores the profiles taught by users and makes them available to other users.
B.A.
If you have a problem, if no one else can help
@Name2Short Thank you for sharing your insightful thoughts on the integration and automation potential of IoT devices with Aqara AI! Your detailed discussion highlights the importance of compatibility and ease of use in making smart home technology accessible to a broader audience. The Aqara G3 hub’s integrated IR remote control is indeed a standout feature, allowing for seamless operation of various devices even in challenging placements. It’s great to see how you’ve envisioned saving energy and increasing comfort through automation and integration with platforms like Apple’s HomeKit.
Your idea of an AI assistant that simplifies the programming of automations and remote control layouts is fascinating. This could significantly reduce the entry barrier for users who might be intimidated by complex setups. By incorporating AI to digitize remote controls and automate tasks through a guided Q&A format, Aqara could indeed enhance user experience and expand its ecosystem’s versatility.
Thank you for contributing such a valuable perspective to the community. We look forward to more of your thoughts and experiences with smart home automation!
@Name2Short Thanks for sharing such a detailed and insightful take on Aqara AI automation, especially around remote control and IR code integration—your focus on ease of use and cross-manufacturer openness really hits the mark for what makes smart home systems accessible and valuable.
You’re absolutely right to highlight the Camera Hub G3’s integrated IR remote-control module, which already helps extend control to devices like TVs, speakers, and streamers (even in tricky positions) . Its hub functionality also lays a solid foundation for such automation setups .
The idea of an AI assistant to simplify programming and digitize physical remotes is a great solution to the time-consuming setup process—addressing that pain point could make Aqara systems even more user-friendly. It’s exciting to think about how community-shared IR profiles could expand support for less common devices too.
Thanks again for contributing this thoughtful perspective—your insights help spark great discussions about where smart home tech can go next. Looking forward to more of your sharing!
