Battery Backup System Setup for Outdoor Cameras
Hey everyone, I wanted to share my experience setting up a battery backup system for my outdoor Wyze V3 cameras. I’ve been dealing with power reliability issues, especially during storms, and wanted a solution that keeps my cameras running even when the power goes out. Here’s what I did:
Setup Overview
  • Battery: I went with a 100Ah battery, which provides enough capacity to keep my 14 cameras, 3 wireless access points, and 3 VOIP lines running for about 21 hours.
  • Power Supply: I repurposed an old power supply/charger to manage the battery. It’s been working great so far!
  • Voltage Regulation: To power the cameras, I used 12V to 5V Micro-USB adapters. These adapters are weatherproof and can handle voltage drops during long cable runs. I’ve been using them outdoors for over two years without any issues.
Safety Measures
  • Each cable run from the power supply is fused at 1, 2, or 3 amps depending on the number of cameras on that branch. This ensures safety and prevents overloading.
  • I also added a Low Voltage Disconnect module to protect the battery from deep discharging.
Challenges and Solutions
One thing I struggled with initially was finding reliable adapters. I tried a few different brands and settled on these IP-67 waterproof adapters which have held up well over time. If you’re looking for alternatives, I’ve also had success with E-Bay converters.
Results
This setup has been a lifesaver during recent power outages. My cameras stayed online, and I didn’t miss a single alert. It’s also been great for peace of mind knowing my security system is reliable.
Tips for Others
  1. Plan Your Wiring: Map out where your cameras are and how many devices will be on each branch to determine the right fuse rating.
  2. Weatherproofing: Make sure all your adapters and connections are weatherproof to prevent moisture damage.
  3. Regular Checks: Periodically check your battery health and ensure all connections are secure.
If anyone has questions or suggestions, feel free to reach out! I’d love to hear how others have tackled similar challenges.
Cheers,
