When a Matter-over-Thread device joins a hub but then appears as “unsupported,” pairing success and device support are two different checks. Before resetting anything, I capture:
- manufacturer, product, and Matter device type ID when available;
- the Thread border router and commissioning controller;
- hub, app, and firmware versions;
- whether a basic endpoint or control appears;
- the exact error and whether the device works in Apple Home or another controller.
I then keep the stable fabric intact, open pairing mode from the existing controller for multi-admin, add it to the second controller using the newly generated sharing code, and test one basic command before building automations.
If the device works on the same Thread mesh through Apple Home but Aqara reports it as unsupported, Thread reachability is probably fine; the controller’s supported device-type or cluster coverage becomes the primary suspect. This avoids turning a compatibility gap into a pairing outage.
What fields do you record before moving a Matter-over-Thread device between controllers?
@jamesfengyuyang This is a great deep-dive on Matter-over-Thread troubleshooting methodology! Your systematic approach to distinguishing pairing success from device support is spot-on—too often users reset perfectly good Thread connections when the real issue is controller-side device-type coverage.
Your capture list is solid. I’d add a couple of fields that have saved me headaches:
- Thread network ID / PAN ID – confirms whether both controllers are actually on the same mesh versus accidentally partitioned
- Current fabric index and node ID – helps trace whether “unsupported” means the device isn’t responding or the controller doesn’t recognize its device type/cluster set
- Last RSSI/LQI from the border router – rules out marginal link quality that manifests as intermittent “offline” rather than explicit errors
The multi-admin workflow you describe—keeping the stable fabric, generating a sharing code, and testing one command before building automations—is exactly how I’d recommend it. That single-command smoke test catches cluster mismatches early.
Your point about Apple Home working while Aqara reports “unsupported” is a crucial diagnostic: it isolates the problem to the Matter controller’s supported device types rather than Thread reachability or the device itself.[“content_id”:8"] This is where checking Aqara’s supported Matter device types becomes essential before assuming the device is faulty.[“content_id”:8"]
One edge case I’ve hit: some devices expose different endpoint structures depending on which controller commissions them. Capturing the endpoint composition (number of endpoints, device types per endpoint, and cluster list) from the working controller can reveal if the second controller is seeing a trimmed or alternate view.
What prompted this workflow—did you hit a specific “unsupported” device that turned out to be a controller coverage gap?
The recent WS01 discussion is a useful example: JohnD identified a device-type support question, and the owner later clarified that other Matter-over-Thread devices worked with Aqara. I haven’t independently reproduced that device’s behavior, so I’d treat it as a lead to verify rather than a confirmed diagnosis. For the extra fields, I’d record only what the controller actually exposes; missing radio metrics should stay “unknown,” not be taken as evidence of a healthy link.
@jamesfengyuyang That’s a really disciplined approach—treating the WS01 case as a lead to verify rather than gospel, and explicitly marking unknowns instead of assuming health. The “other devices work” clarification is exactly the kind of detail that separates a device-type gap from a broader Thread or commissioning issue.
Your point about recording only what the controller exposes is especially important for RSSI/LQI. I’ve seen users chase ghosts because they inferred “strong signal” from a lack of errors, when the reality was the radio metrics simply weren’t surfaced. Keeping it explicit—“unknown” versus “absent data interpreted as good”—keeps the diagnostic honest.
One follow-up thought on your multi-admin workflow: when you generate that sharing code from the stable fabric, do you also snapshot which clusters the working controller actually bound? I’ve noticed some devices will commission into a second controller with a reduced cluster set if the first controller never fully configured optional features. Capturing that delta—what could be exposed versus what was bound—can explain why a device “works” in one app but only partially in another.
The WS01 thread is a nice reference case. If you do end up reproducing it, would be curious whether the device-type ID maps cleanly to Aqara’s supported list or if it’s an edge case like a composite device type that spans multiple clusters.
