Hi everyone, I have a few G5 Pro PoE cameras connected to the same PoE switch and I’d like to set up reliable 24/7 local recording.
I understand the G5 Pro supports both SMB NAS storage and RTSP, but I’m trying to decide which route works best with six cameras (planning to increase to around 8):
- native SMB recording directly from each camera to a NAS
- RTSP into an NVR or software such as Frigate, Blue Iris or Synology Surveillance Station
For anyone running a similar multi-camera setup, which approach has been the most reliable? I’d be interested in the NAS or recorder you use, storage capacity and retention time, how easy it is to review footage, and whether six continuous streams cause any network or performance issues.
Does native SMB provide proper continuous recording and a usable timeline, or is RTSP into dedicated NVR software the better experience? I’d also like the system to keep recording locally if the internet connection goes down.
Any real-world setup details or lessons learned would be appreciated.
@yousifnajjar Great question, and you’re clearly thinking through this the right way for a multi-cam setup! Let me share what I know from the official specs and some practical considerations.
On native SMB NAS recording: The G5 Pro supports NAS storage via SMB, and Aqara has noted that 24/7 continuous recording functionality for NAS is actively being worked on and will come in an upcoming firmware update[“content_id”:7"]. So if you’re planning this now, keep in mind that true 24/7 timeline recording via SMB may not be fully available yet—worth checking your current firmware version.
On RTSP into NVR/software: This is where the G5 Pro really shines for DIY flexibility. The camera supports RTSP streaming for local network integration with NVRs, Home Assistant, VLC, and other platforms[“content_id”:1"][“content_id”:3"]. For your 6-8 camera scale, RTSP into something like Frigate, Blue Iris, or Synology Surveillance Station will likely give you:
- Proper continuous recording with scrubbable timelines today
- More control over retention policies and storage management
- Better handling of multiple streams without relying on each camera’s individual SMB client
A few gotchas with RTSP: After a factory reset, your RTSP credentials will change and you’ll need to reconfigure third-party clients[“content_id”:3"]. Also, the camera doesn’t support ONVIF auto-discovery, so you’ll need to add streams manually—Hikvision NVRs are tested, but other brands may have quirks[“content_id”:4"]. Make sure your camera and NVR/recorder stay on the same network segment[“content_id”:3"].
For local resilience: Both approaches should keep recording without internet, though RTSP to a local NVR is arguably more self-contained. Your PoE switch powering everything is already the right foundation there.
My take: Given your camera count and that you want reliable 24/7 with usable timelines today, RTSP into dedicated NVR software is probably the smoother experience right now. Once Aqara rolls out the full 24/7 NAS firmware, SMB could become more competitive—especially if you prefer a simpler, camera-direct-to-storage architecture.
What’s your current NAS or server hardware? That might tip the scales on whether Frigate (if you have a Coral TPU handy) or something like Surveillance Station makes more sense.
I have two G5s streaming via RTSP to a UGREEN NAS, and it’s been working really well. The UGREEN Surveillance System is a free app and easy to install. It doesn’t have many functionalities, but it covers the basics like recording and reviewing footage.
However, if you have the G5 PoE version and they support ONVIF, the UGREEN NAS has some interesting local AI free app that can process the video and generate events such as people, pets, cars, etc.
If you decide to go this route, just make sure you get one of the UGREEN NAS models that supports Docker. I have the DXP2800.
