Hi all! I run Home Assistant in Docker on a Mac mini in Stockholm, and I have an Aqara U200 lock. I’m planning to add more Aqara devices (sensors and maybe a camera) and I’m unsure which route works best: Matter via an Aqara hub, the HomeKit Device integration, or something else. Since Docker on macOS can’t do host networking properly, discovery is sometimes tricky. What setup are you using, and what has been most reliable for you? Thanks!
@jacob_westfeldt Great question, and the Docker-on-Mac networking limitation is definitely something to plan around! For your U200 and future Aqara devices, you have a few solid paths depending on what you’re adding.
For your U200 lock specifically, since it supports Matter & Thread, you’ll need an Aqara hub that also supports Matter & Thread — currently the M3, G5 Pro, or M100 are your options, with more hubs coming later. The U200 can pair directly to Apple Home if you have a Thread border router like a HomePod mini, but for Home Assistant integration, a Matter-compatible Aqara hub is your bridge.
For broader Home Assistant integration, here are your main routes:
| Method | Best For | Notes |
| Matter via Aqara Hub (M2/M3 with updated firmware) | Sensors, switches, lights, lock | Child devices expose to Matter ecosystems; works cross-platform without HomeKit dependency |
| HomeKit Controller | HomeKit-certified Aqara devices | Direct pairing to HA; requires device reset and pairing code |
| Aqara Hub + HomeKit Controller | Existing Zigbee devices via M2/M1S/G3 | Simplest for beginners; hub and HA must be same network |
The Docker-on-Mac gotcha: Since --network host doesn’t work properly on macOS, mDNS discovery can be painful. For Matter/Thread, ensure your Mac mini and any Thread border router are on the same IPv6-enabled network — this is non-negotiable for Matter. You might need to manually specify IP addresses or use a multicast relay container to help with discovery.
My take: If you’re already in the Apple ecosystem with a HomePod mini, the U200 can live there via Thread, then bridge to HA through the Matter hub. For sensors and cameras, the Matter route via an M3 gives you the most future-proofing and avoids HomeKit’s feature limitations.
What’s your current Thread border router situation? That might narrow down the cleanest path for you.
Welcome to the forum, @jacob_westfeldt !!!
The problem is really Docker on macOS. Matter needs host networking, mDNS and IPv6 on the same network as your devices, and Docker on Mac runs everything inside a small VM with its own network. Discovery will always be difficult like that.
What I would do: run Home Assistant OS in a VM on the Mac mini (UTM works) with a bridged network card, so HA gets its own IP on your network like a real device. After, add the Aqara devices with an Aqara hub that has Matter (M3 or M100) and the Matter integration. Your U200 can go on the same hub. It’s much simpler after that.
