Binding with smartthings, devices not showing in smartthings
I have a m3 hub and several switches attached to it.
I have bind Aqara apps but no aqara devices appear in smartthings.
Hi @srrae , what models of switches are we talking about, maybe they just don’t support integration into SmartThings
How are you connecting the M3? Are you using matter to bring it over or setting up via the partner link? Using matter should bring over everything you have bound to the M3.
I’m trying to add it through smartthings app by scanning the matter code. But the app says waiting for the hub to be in pairing mode .
What I did was open the Aqara app, go to the M3 -Third part matter controllers-matter pairing code (copy code) which should put it in pairing mode and then I went back into the SmartThings app and it popped up for pairing. If not you can follow the steps in the SmartThings app to add a device via matter.
I’m trying that, but isn’t working
Are you using an iPhone?
No. Android. I’ve see that thing about removing matter from your phone. It wasn’t there.
A few times it shows up to pair but it says the matter code isn’t associated with that device
