# Boost FP2 mmwave radar Performance & Accuracy - Maximize Accuracy Pro Tips for FP2, FP1E and more 🚀
Millimeter-wave radar products like the Aqara FP2 rely heavily on proper installation. When set up right, it’s a total game-changer – precise positioning, zone triggering, and it can even replace multiple sensors! But if you skip proper debugging before use, you might run into unexpected issues. Common user complaints like “ghost detections,” missed alerts, or failure to detect “no one” can all be fixed with the right setup. Let’s make your FP2 work like a pro!
Want to get the best detection performance from your Aqara FP2? Follow these steps to install and debug it easily – no more inaccurate detection headaches! :blush:
1. Choose the Right Installation Location & Angle :round_pushpin:
Wall Mount (Side Installation)
Install the sensor in the center of a wall, such as above your living room TV cabinet or sofa wall. We recommend a height of 1.8–2.2 meters. After mounting, adjust the angle up/down by hand so it faces the area where people move most. This way, the radar will cover both sitting and standing heights, making the detection range more effective.
Pro tip: Keep the device logo horizontal, and make sure the front faces the area you want to monitor!
Corner Mount
The radar has a 120° field of view (FOV). To avoid blind spots, mounting it in a corner is a great choice. Install it in a living room corner at a height of 2.2–2.4 meters, then tilt it downward so it targets the main activity area (covering both sitting and standing heights). Corner mounting expands the horizontal detection angle and reduces blind spots that might occur with wall mounting.
Remember: Aim the device toward the center line of the corner!
2. Avoid These Installation Spots :x:
Steer clear of mounting the sensor facing:
  • Large metal surfaces, glass, or other highly reflective materials (they mess with radar signals).
  • Areas with air flow, like air conditioner vents, air purifiers, fans, or curtains.
Strong interference in these environments will seriously affect the millimeter-wave radar’s accuracy.
3. Key Steps for Zone Calibration :hammer_and_wrench:
① Mark “Edge Zones”
Open the Aqara app and mark areas you don’t need to monitor as “Edge Zones.” This stops false alerts like “ghost detections” caused by reflection interference.
② Mark Entrances/Exits
In the app, tag all entrances and exits in your monitored zone. This helps the sensor quickly detect “someone present” or “no one present” status, drastically reducing false or missed alerts.
③ Mark Interference Sources
If there are devices like oscillating fans or motorized curtains in the area, mark them as “Interference Sources” in the app. This prevents false “someone present” alerts triggered by these moving objects.
④ Run “AI Spatial Background Learning”
After installation, make sure no one is in the detection range, then run “AI Spatial Background Learning” in the app. This lets the device learn your space’s energy patterns for super accurate detection!
⑤ Adjust Presence Detection Sensitivity
You can adjust sensitivity in the app. Higher sensitivity makes it easier to trigger and maintain “someone present” status – perfect for areas where people move little, like beds or sofas.
4. Test After Installation :white_check_mark:
Once installed and debugged, always do a real-world test! Ask someone to walk in and out of the detection area to check if the sensor counts people correctly.
If detection is inaccurate:
  • First, check the environment and remove interference.
  • If that doesn’t work, try a new installation location.
  • Keep adjusting until you get perfect results!
Follow these steps, and your Aqara FP2 will deliver pinpoint detection every time. Enjoy! :blush:
#AqaraFP2 #InstallationTips #DebuggingGuide #AccurateDetection
These tips are designed to be easy to follow. If you think some parts need to be more concise or have other adjustments, feel free to let me know.
@MakerMing Thank you for sharing these insightful installation and debugging tips for the Aqara FP2! Your detailed guide is invaluable for ensuring optimal performance of the millimeter-wave radar sensor. Proper installation indeed makes a huge difference in achieving precise positioning and effective zone triggering.
Your emphasis on choosing the right installation location and angle, whether it’s a wall or corner mount, aligns perfectly with the recommended practices. Avoiding reflective surfaces and areas with airflow is crucial to minimize interference, which you highlighted very well.
Marking edge zones, entrances, exits, and interference sources, as well as utilizing the “AI Spatial Background Learning” feature, are excellent strategies for optimizing detection accuracy. Your tip on adjusting presence detection sensitivity is a great reminder for users to tailor settings based on their specific environment and needs.
Testing after installation is vital, and your guide encourages users to tweak the setup until they achieve optimal results. This proactive approach can save much time and frustration down the road.
Thank you for contributing this valuable information, and please keep sharing such helpful content. If anyone has further questions or tips, feel free to jump in and keep the discussion going! :blush:
If you encounter any problems installing Presence Sensor FP2, check this.
Ich möchte den FP400 in Deutschland Testen und die Funktionen des FP400 nutzen habe ich einen M3 Hub mit mindestens Firmware-Version 4.5.70
Du bist hier verkehrt.
Does a UST Laser Projector cause any interference? I’m contemplating on ordering the FP400 to my living room if it is available tomorrow 16.9! Do the same tips apply for it as well?
