Bugs in the Latest Hub M3 Update
Hello,
After the recent update of my Hub M3 (4.3.7_0036), the “absence/opened for more than a period” integration stopped working — automations are no longer updating.
I’m also unable to add new Matter devices shared through Apple Home (Eve Matter Smart Plug and Eve Matter Motion Sensor). I tried the solution from a forum thread, but it didn’t work.
Is anyone else facing the same issue? Any workaround would be appreciated.
what solution from the forum did you use but it didn’t work?
I’ve tried this one for the Matter device without success.
The issue with the automation is still happening.
Ill add to this, my M2 hub doesnt disable / enable automations when command given by automation…
The M3, HomePod and iPhone are under the same network? did the issue appear after update?
Yes! They are on the same network, and the M3 is connected via Ethernet.
The issue appeared after the 4.3.7_0036 update and persists on 4.3.8_0021.
Recently, I was able to share a Matter-over-Thread device from a different brand through Apple Home, and it worked. It seems that the issue is with Eve devices.
