Hola tengo 4 camaras G3 y 2 cámaras G3 y 3 cámaras G2H pro en casa de mi madre tengo un problema con el almacenamiento local ósea las tarjetas de memoria en unas cámaras puedo ver lo que ha pasado y en otras no selecciono sobreescribir que es cuando se llenan empieza a grabar por el principio pero hay algunas que cuando se llena ya no se graba nada
The inability of SD cards to cyclically overwrite previous video files is usually caused by the following reasons:
The file index recorded in the SD card is damaged, usually due to sudden power outages or other situations. We have optimized the robustness of the index file in the new firmware. First, please ensure that the firmware is the latest version. If the problem has already occurred, please backup the data first, and then reformat the SD card from the app to observe if it is normal.
Some SD cards have quality issues and may suddenly experience a decrease in capacity, causing the camera to determine that the reserved space is insufficient and unable to overwrite. This can be verified by exchanging the SD cards of two diffrent cameras. If it is determined to be an SD card issue, it needs to be replaced.
