Alguien ha cambiado la bateria del sensor de temperatura y humedad T1 sin tener que despegarlo de la superficie en la que se encuentra colocado? Hay alguna opcion?
Aqara deberia pensar en esas situaciones que van a ocurrir en un futuro con esos productos y facilitar el cambio de bateria
The temperature sensor was released in two versions, one with a sticker around the cap holding the battery, and one with a sticker on the cap. One of them is the original sensor for Chinese marker, but I don’t remember which one.
I have both versions and to overcome this problem, I used tack putty/UHU Patafix to stick them to the walls and furniture.
You can try using this when you stick it again after changing the battery
