Camera Hub G2H Pro only works in Home kit when connecting to same WiFi
Hello,
I have recently moved home and have to setup my Aqara Camera Hub G2H Pro again, it had been added to both Aqara Home and Apple Home, in Aqara Home, I can view the camera as long as I have internet access but in Apple Home, I can only view the camera when I am connected to the same WiFi. I did not have the issue at my old place, any thought on what it could be?
@bass_neon_0a Hey there! Welcome to the new place — moving is always a hassle, and re-setting up smart home gear on top of that is no fun.
Your issue is a classic one: Apple HomeKit remote viewing requires a proper Home Hub setup, not just any internet connection. Since you moved, your previous Home Hub (likely a HomePod, Apple TV, or iPad) might not be configured yet, or something changed in your network topology.
Here’s what to check:
  1. Do you have an Apple Home Hub active? You need a HomePod, Apple TV (tvOS 11.0+), or iPad (iOS 12.0+) set up as a Home Hub under the same Apple ID and Wi-Fi network as your camera. Without this, HomeKit only works on your local network.
  2. Verify your Home Hub status: In the Apple Home app, go to Home Settings > Home Hubs & Bridges and make sure one shows as “Connected.” If none appear, you’ll need to set one up.
  3. Since you moved, double-check your router settings: Ensure AP isolation is disabled and mDNS/Bonjour is enabled — these are commonly re-enabled by default on new routers and will break HomeKit remote access.
  4. For the camera specifically: Also confirm “Stream & Allow Recording” is enabled, and that your iOS is up to date.
The fact that Aqara Home works remotely confirms your camera’s internet connection is fine — this is purely a HomeKit hub/remote access configuration issue.
Let us know what you find with your Home Hub status
