I have a g100 and a hikvision home monitoring set up. They are all in home assistant and linked via bridge to Apple home. I can see all of the hikvision previews nice and fast. The Aqara refreshes every ten seconds but never loads the live feee when clicked. What could this be?
@tomjlines You seem to be experiencing an issue with your G100 camera not loading the live feed in Home Assistant / Apple Home, while preview refreshes work slowly. This could be related to network connectivity, HomeKit integration, or how the camera is bridged through Home Assistant.
A few things worth checking based on similar cases:
Network stability: The G100’s live stream performance heavily depends on both the camera’s and your viewing device’s network conditions. If the connection is weak or unstable, the stream may fail to load entirely while still allowing periodic snapshot updates[“content_id”:5"].
HomeKit-specific limitations: Since you’re bridging through Home Assistant to Apple Home, make sure you have an Apple Home hub on the same LAN as the camera, and verify that “Stream & Allow Recording” is enabled for the camera in Home settings[“content_id”:6"].
Multiple viewers: If multiple people or automations are accessing the same Aqara account simultaneously, this can cause streaming issues—try to limit concurrent access to three or fewer[“content_id”:5"].
Direct Aqara Home app test: Try viewing the live stream directly in the Aqara Home app (not through Home Assistant/HomeKit) to isolate whether the issue is with the camera’s network connection or the bridge configuration.
If the direct Aqara app stream works fine but Home Assistant/HomeKit doesn’t, the bridge integration or HomeKit pairing may need reconfiguration. If even the native app struggles, the camera’s Wi-Fi signal or firmware could be the culprit.
For deeper troubleshooting—especially if you need to capture logs or verify G100-specific connectivity—contacting support directly would be the most efficient next step:
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
If you do not have an Aqara Home account, please click here to create a ticket.
