Camera picture is oblique
I installed the G5 Pro outside. Unfotunately the camera is not oblique so the picture is not oblique as well. is there a chance to turn the camera picture? i only found the 180 degrees turn.
Hi @ivoschwarz there’s only possible to turn it upside down by app as you mentioned.
The other corrections must be done manually by mounting the cam in the right direction - but this should be possible by turning the mounting bracket into the right position!
If not possible for you, please sent a picture and I try to help you
Hello @ivoschwarz
That’s right, the camera in the app can only rotate 180 degrees. You need to position it accordingly. If you can’t get the image you need on the standard bracket, I’d recommend purchasing a suitable bracket for custom placement.
As mentioned above, please attach images for a clearer understanding of the problem. Thank you.
