Camera will not connect
Unplugged camera and now it will not connect, get to input network connection: successful, pairing failed. Tried 20 times now no solution.
Hi,
What camera shown this issue? Please give us more details
Which camera is it? WiFi or Ethernet?
If your Aqara camera reports “Network connection successful” but then “Pairing failed,” please try the following steps:
  1. Restart the camera and your router.
  2. Make sure your network connection is stable (2.4 GHz Wi-Fi if required by your camera).
  3. Update the Aqara Home app to the latest version.
  4. Check whether the camera is already registered in Aqara Home.
  5. If necessary, reset the camera and try pairing again.
If the issue persists, please provide the following information:
  • Which Aqara camera model are you using?
  • Are you pairing it through Aqara Home or Apple Home?
  • Is the camera connected via Wi-Fi or Ethernet?
  • Which server/region is selected in the Aqara Home app, and was the camera purchased locally or imported from China?
This information will help us identify the cause and suggest the appropriate solution.
