Can any Aqara switches handle 3 way lights?
I have 2 three way lights in my house. On one switch I have a 3 way switch from another manufacturer, but it can be unreliable at times. I see Aqara has more switches now, but their single button switch doesn’t support 3 way control, it seems.
@deviladv It’s great to see your interest in enhancing your home lighting setup with Aqara products! For your three-way light switch needs, the Aqara Light Switch H2 US (2 Buttons, 1 Channel) could be an excellent choice. This switch supports three-way control, meaning you can control one light from two different locations, which aligns perfectly with your requirement for three-way lights.
To achieve the best stability and convenience, it’s recommended to use two Aqara Light Switch H2 US units to create a Quick Two-way Control. This setup allows for a more reliable connection, especially if you’re experiencing issues with your current setup.
If you’re considering installation, please note that identifying the type of electrical circuit in your home is crucial. The Aqara Light Switch H2 US supports multiple circuit types, including single pole and two variations of 3-way circuits. For accurate installation, especially with 3-way circuits, consulting a professional electrician is advisable.
For more details, you can check out the Aqara Light Switch H2 US product page. Feel free to reach out if you have more questions or thoughts to share!
@deviladv Yes, several Aqara switches and modules can handle 3-way lighting setups.
The Aqara Light Switch H2 US supports 3-way wiring, with a maximum wiring distance of up to 20 meters between the new switch and the original switch in a 3-way setup. For better stability and convenience, it’s recommended to use two Aqara Light Switch H2 US units for Quick Two-way Control .
The Aqara Smart Wall Switch H1 (No Neutral Triple Rocker) offers Multi-Way Control, allowing you to control the same lights from two or more locations by adding a wireless switch—no new wiring needed .
Additionally, the Aqara Dual Relay Module T2 supports multi-way switch setups when used with a wireless switch, which can be placed anywhere to control the module .
If you’re looking for specific models, these options might fit your needs. Have you considered any of these models yet? Feel free to share more details about your setup, and the community can help further!
@deviladv It’s great that you’re exploring Aqara switches for your 3-way lighting needs! From the available information, some Aqara switches do support multi-way or 3-way control. For example, the Aqara Smart Wall Switch H1 (No Neutral Triple Rocker) features “Multi-Way Control,” allowing you to control the same lights from two or more locations without new wiring by adding a wireless switch. Additionally, the Light Switch H2 US models include “3-Way Control” as part of their functions.
If you’re considering these models, they might offer the reliability you’re looking for. Have you checked the specific compatibility with your home’s wiring? Feel free to share more details about your setup—other community members might have similar experiences to share!
