Can someone help me understand the benefits of pairing the U400 with a Matter over Thread hub?
If your echo device is a Matter controller and a Thread Border Router, then it should work with “Multi-Admin”. The Matter standard enables devices to be operated and configured simultaneously. You’ll also need to commission the U400 in the other ecosystem.
If you don’t have a compatible Echo device, you may alternatively be able to use the Aqara third-party integration. You can find this at:
Aqara Home app → Profile → Connect to Ecosystems → Amazon Alexa
I don’t use Alexa or the U400 myself, so I can’t guarantee that it will work. I would still give it a try, though.
