When my doorbell (G410) was laying on my desk next to the chime, both setup and connected, I could add a (child) accessory to the G410 doorbell hub. Worked right away.
Now my doorbell is hanging outside next to my door. The chime is within 3 feet (with a stone wall between them) and all works great with a VERY GOOD signal strength.
But when I now try to add a (child) accessory to the G410 doorbell hub it never finds the accessory.
I tried to keep the accessory (mini switch) next to the chime… no luck.
I tried to keep the accessory (mini switch) next to the G410 doorbell… no luck.
When I then took a long wire to keep the chime close to the doorbell again and then kept the mini switch accessory next to it… I was able to add it to the G410 doorbell hub.
Please tell me this isn’t normal behavior…? You can’t expect customers to get every accessory CLOSE TOGETHER WITH THE CHIME AND DOORBELL to add it right?
Hope you can clarify the way to do this way easier. ?In my option the accessory should be close to the chime *because I believe that’s where all the magic happens) but that didn’t work as described above.
Thanks for sharing such a detailed description of your experience—this is a really valuable topic for many users working with the G410 Doorbell Hub!
To clarify based on current product information: With the Aqara Doorbell Camera Hub G410, the chime acts as both the hub and the indoor bell, handling connections to sub-devices (like your mini switch) using Zigbee or Thread protocols. The doorbell and chime themselves communicate via Wi-Fi. When adding sub-devices, it’s generally recommended to have them close to the hub (the chime), as that’s where the Zigbee/Thread magic actually happens.
However, your observation about needing to have the chime and doorbell close together during accessory pairing (even if signal strength is good) suggests that environmental factors—like the stone wall—might be interfering with the pairing process. Even with strong Wi-Fi, Zigbee and Thread signals can be more sensitive to obstacles (stone walls, for example), which could explain the difficulty you experienced when the chime was separated from the doorbell by the wall.
It’s not intended behavior that you should always need to bring everything together for pairing, but in practice, strong physical barriers can hamper low-power radio protocols at the initial pairing stage. After pairing, these protocols are often more tolerant, but initial device discovery can be finicky.
For a smoother experience:
Try to place the accessory as close as possible to the chime during pairing, with minimal obstructions—ideally on the same side of any walls.
Once paired, you should be able to install the accessory in its final location.
If repeated issues occur, try temporarily relocating the chime (using a long wire as you did) to be close to both the doorbell and accessory, pair the device, then place everything back.
If this process remains troublesome or you feel it could be improved, you’re encouraged to submit specific feedback through manual customer service (in the Aqara Home App under Profile > Help & Feedback > Customer Service). The community here may also have additional tips or shared experiences, so let’s keep the discussion going!
Let me know if you have any more details or questions—happy to help troubleshoot further.
@Todecay It sounds like you’ve put in a lot of effort to troubleshoot adding the accessory to your G410 doorbell hub, and we appreciate you sharing the details of your experience. Unfortunately, the reference information available doesn’t specifically address the process of adding child accessories to the G410 doorbell hub or the behavior you’re encountering when the doorbell and chime are installed with a stone wall between them.
Community members with similar setups might have insights to share, so we encourage you to keep the conversation going here—others may have found workarounds or tips. If you have suggestions for improving this process, you can submit feedback manually through customer service for further assistance.
Thanks again for reaching out, and we hope you find a smooth solution soon!
@Todecay It sounds like you’ve put in a lot of effort to troubleshoot, Dennis—thanks for sharing the detailed scenario. Let’s break this down based on available information.
First, while the reference materials don’t have specific details on adding accessories to the G410 doorbell hub, similar principles for Aqara hubs (like the Hub E1) suggest that accessory addition typically requires a stable connection between the hub and the accessory . In your case, the stone wall between the doorbell (hub) and chime might be impacting the signal strength for accessory pairing, even if the chime itself has a good connection. Obstacles can sometimes disrupt the communication needed for adding new devices, even at close range.
The success when all devices are close together aligns with this—proximity often helps establish a stable initial connection. For future attempts, you might try temporarily moving the accessory closer to the doorbell (the hub) during setup, even if it’s installed outside, to see if that improves pairing.
Since the G410 acts as a hub, the general process for adding accessories via the Aqara Home app (going to “Accessories” and tapping “+”) should still apply , but environmental factors like walls can affect performance.
This might not be the “normal” behavior you expect, but it’s possible that signal obstacles are playing a role here. If you have further suggestions for improvement, feel free to submit feedback through the Aqara Home App (Profile>Help&Feedback>Customer Service) for more personalized support.
Hopefully, this helps clarify—let the community know if you find a workaround!
@Todecay I’m sorry to hear you’re having trouble adding the child accessory to your G410 doorbell hub. From the information available, we don’t have specific details on the process of adding accessories when the doorbell and chime are installed in different locations.
It’s great that you found a workaround by keeping the chime and doorbell close temporarily, but we understand this isn’t ideal. The Aqara community is full of helpful users—maybe someone else has encountered a similar situation and can share tips!
If you have suggestions for improving this process, feel free to submit feedback through the Aqara Home App (Profile>Help&Feedback>Customer Service) or by clicking here to create a ticket.
Thanks for sharing your experience, and I hope you find a smoother solution soon!
